I recently ran into the issue, that my list item widgets do not appear properly.
As soon as I embed my f7-list widget into the oh-list-card, the widget is indented, as shown below:
Even if I add the CSS style property “margin-left” or (absolute position) “left” with a negative offset, the issue cannot be solved.
Using “margin-left” will result in an impure solution that only works on the web page, but this does not affect the page layout on mobile devices.
Do you guys have some ideas to solve this indentation?
uid: widget_manualHeatingPhase
tags: []
props:
parameters:
- description: Title of the acordion list
label: Title
required: false
type: TEXT
- description: "Icon for the widget elements (e.g.: f7:flame)"
label: Icon
required: false
type: TEXT
- description: 'An array of labels (e.g.: "Bedroom;Livingroom;...")'
label: Labels
required: false
type: TEXT
- description: 'Color shown if the radiators are on (e.g.: "red,orange,...")'
label: ON Color
required: false
type: TEXT
- description: 'Color shown if the radiators are off (e.g.: "gray,blue,...")'
label: OFF Color
required: false
type: TEXT
- description: "Minimal temperature which can be set (e.g.: 15)"
label: Min. Temperature
required: false
type: TEXT
- description: "Maximal temperature which can be set (e.g.: 25)"
label: Max. Temperature
required: false
type: TEXT
- context: item
description: Item(s) holding the set point value
label: Linked Set Point Item(s)
required: true
type: TEXT
multiple: true
- context: item
description: Item(s) holding the current temperature
label: Linked Current Temperature Item(s)
required: true
type: TEXT
multiple: true
- context: item
description: Item(s) holding the current valve tappet
label: Linked Valvet Item(s)
required: true
type: TEXT
multiple: true
parameterGroups: []
timestamp: Oct 10, 2022, 10:32:39 AM
component: oh-list-item
accordionList: true
mediaList: true
icon: f7:flame
iconColor: gray
title: =props.title
slots:
accordion:
- component: f7-list
mediaList: true
slots:
default:
- component: oh-repeater
for: i
fragment: true
in: =props.linkedSetPointItems
sourceType: array
slots:
default:
- component: oh-stepper-item
buttonsOnly: false
fill: true
icon: f7:flame
iconColor: "=(items[props.linkedCurrentValveTappetItems[loop.i_idx]].state > 0) ? props.onColor : props.offColor"
item: =loop.i
large: true
max: =props.max
min: =props.min
round: true
title: =props.labels.split(";")[loop.i_idx] + " (" + items[props.linkedCurrentTemperatureItems[loop.i_idx]].state + ")"
