OH3 - oh-repeater use stateDescription of item
Hey guys,
I tried to work on a popover widget to select a hue scene. This is my actual code:
uid: scene_select
tags: []
props:
  parameters:
    - context: item
      description: Item an welches die Szene gesendet wird
      label: Szene
      required: true
      type: TEXT
    - description: Vordefinierte Szenen
      label: Vordefinierte Szenen
      required: true
      type: TEXT
component: f7-card-content
  padding: false
  class:
    - margin-vertical
    - display-flex
    - flex-direction-column
    - flex-justify-content-flex-start
    - flex-align-items-center
slots:
  default:
    - component: f7-list
      slots:
        default:
          - component: oh-repeater
              for: preset
              in: =props.itemScene_select.split('|')
              fragment: true
            slots:
              default:
                - component: f7-list-item
                    title: =loop.preset.split(";")[1]
                    visible: =loop.preset != ""
                  slots:
                    after:
                      - component: oh-button
                          text: 'Anwenden'
                          actionItem: =props.itemScene
                          actionCommand: '=loop.preset.split(";")[0].toString()'
                          action: command
                          class:
                            - popup-close
        popupClose: true
        round: true
        fill: true
        large: true
        text: 'Abbrechen'
        class:
          - margin-horizontal
I can add scenes like:
cybRt-6DWuJQ49s;scene1|qQDnR8betNS0OuL;scene2
The openHAB API explorer gives me the following stateDescription (commandDescriptions are the same values):
"stateDescription": {
    "pattern": "%s",
    "readOnly": false,
    "options": [
        "value": "cybRt-6DWuJQ49s",
        "label": "Energie tanken"
        "value": "qQDnR8betNS0OuL",
        "label": "Entspannen"
        "value": "HMjIpLrIpk-O8SR",
        "label": "FrĂĽhlingsblĂĽten"
        "value": "61V3SbEuH8IEg9O",
        "label": "Gedimmt"
        "value": "-EL9hhL8FFh0Q4X",
        "label": "Hell"
        "value": "IcV4aE9kvXTTPE7",
        "label": "Konzentrieren"
        "value": "225KFWQ-tMT4Gix",
        "label": "Lesen"
        "value": "qxqIuCmQypoBZIQ",
        "label": "Nachtlicht"
        "value": "4VMKYdkj7JdT93G",
        "label": "Nordlichter"
        "value": "To9Vnqyy6dyqx4Q",
        "label": "Sonnenuntergang Savanne"
        "value": "ieHpE7GIUYpu5qi",
        "label": "Tropendämmerung"
Any ideas how I can use the stateDescription in oh-repeater? :thinking:
Thank you :slight_smile:
  sourceType: itemStateOptions # or itemCommandOptions
  itemOptions: =props.itemScene
The doc page has a bug due to unescaped quotes so you can’t see the possible options for sourceType - see the raw source https://raw.githubusercontent.com/openhab/openhab-webui/main/bundles/org.openhab.ui/doc/components/oh-repeater.md
Thank you so much :slight_smile:
This is my actual solution:
      slots:
        default:
              itemOptions: =props.itemScene_select
              for: option
            slots:
              default:
                    title: =loop.option.label
                    visible: =loop.option.label != ""
                  slots:
                    after:
                          text: 'Anwenden'
                          actionCommand: =loop.option.value
                          action: command
                          class:
                            - popup-close
