IC.
My influxDB system fails with a timeout during startup, and my RRD4j system is not able to persist strings?
Since Default_Day.sendCommand(“09:00:00”), why does both systems change state at 10:00?
2023-05-26 10:00:00.006 [INFO ] [omation.rules_tools.TimeStateMachine] - Transitioning Time State Machine from MORNING to DAY
2023-05-26 10:00:00.007 [INFO ] [omation.rules_tools.TimeStateMachine] - Transitioning Time State Machine from MORNING to DAY
2023-05-26 10:00:00.010 [INFO ] [omation.rules_tools.TimeStateMachine] - Transitioning Time State Machine from MORNING to DAY
2023-05-26 08:00:00.002 [INFO ] [omation.rules_tools.TimeStateMachine] - Transitioning Time State Machine from NIGHT to MORNING
2023-05-26 10:00:00.001 [INFO ] [omation.rules_tools.TimeStateMachine] - Transitioning Time State Machine from MORNING to DAY
And Default_Morning.sendCommand(“06:00:00”) at 07:00?
Is it related to Regional time setting? (Which don’t seem to follow DST automatically).
MapDB configured to just do restoreOnStartup. It’s embedded so it will always be there and it will be very fast.
rrd4j for stuff you want to chart configured without restoreOnStartup
External databases only for those Items you want to do some serious analysis on using external tools
This gives the maximum robustness to meet all of those requirements.
You’ve got a timezone issue somewhere. There are multiple places where the timezone can be taken from:
operating system
JVM
openHAB regional settings
Most of the time, when there is a problem with timezones it can be fixed by setting it on the JVM side. There are tons of posts on the forum but I believe it just involves adding extra options to the java command that kicks off OH and there is a config file somewhere that does that. I don’t have an installed version of OH, just Docker and I can set the timezone through an environment variable with that sort of install. I can’t tell you where it is on an installed OH.
Still all state changes are 2hrs behind.
I decided to take a more simple approach:
// Time Of Day
rule "06_00"
Time cron "0 0 6 ? * * *" // 06:00
TimeOfDay.sendCommand("MORNING")
logInfo("TimeOfDay", "Transitioning from BED to MORNING")
rule "09_00"
Time cron "0 0 9 ? * * *" // 09:00
TimeOfDay.sendCommand("DAY")
logInfo("TimeOfDay", "Transitioning from MORNING to DAY")
rule "18_00"
Time cron "0 0 18 ? * * *" // 18:00
TimeOfDay.sendCommand("EVENING")
logInfo("TimeOfDay", "Transitioning from DAY to EVENING")
rule "23_00"
Time cron "0 0 23 ? * * *" // 23:00
TimeOfDay.sendCommand("NIGHT")
logInfo("TimeOfDay", "Transitioning from EVENING to NIGHT")
rule "00_00"
Time cron "0 0 0 ? * * *" // 00:00
TimeOfDay.sendCommand("BED")
logInfo("TimeOfDay", "Transitioning from NIGHT to BED")
vDayOfWeek.sendCommand(now.getDayOfWeek.toString())
logInfo("System", "DAY=" + now.getDayOfWeek)
Works fine:
yaml
omr@shs2:~$ grep -i transition /var/log/openhab/openhab.log | grep -i trans
2023-06-01 20:00:00.003 [INFO ] [omation.rules_tools.TimeStateMachine] - Transitioning Time State Machine from DAY to EVENING
2023-06-01 23:00:00.496 [INFO ] [.openhab.core.model.script.TimeOfDay] - Transitioning from EVENING to NIGHT
2023-06-02 00:00:00.495 [INFO ] [.openhab.core.model.script.TimeOfDay] - Transitioning from NIGHT to BED
But, I will always wonder why it didn’t work out with the template …
