- Platform information:
- Hardware: OH3 in LXC
- OS: Debian
- Java Runtime Environment: as per recommendation for OH3
- openHAB version: OH3 latest release
- Issue of the topic:
I am experiencing a strange behavior in which when I go the i.e. the Locations tab and open the Bathroom (or any other card connected to a dimmer) executes a command that activates the light.
I could narrow it down to the fact that it seems to be executed on the dimmer item which in turn than turns on the lamp as well (i.e. the dimmer gets a value send when opening the card).
An example dimmer item I got is
(I got the same behavior on 5 other light bulbs, they are defined the same way though):
And this is the log:
Executing those dimmer commands when opening the card should not happen (I think), hence is there anything I have to change in my (dimmer) items?
Thanks!
