Hi @apella12, yes I know they are just “/openhab”, but my log shows it still searching for openhab2 folders. I would like to know where in which config file I can adjust the addons folder to reflext it to /openhab for OH3.
Could it be that you created a shell script in /etc/profile.d ( like openhab.sh ) that sets environment variables. This script may not have been adapted.
If that does not help you can do something like:
find / -type f -exec grep -l openhab2 {} \;
That should print out filenames of files that contain the string openhab2.
Better than starting the search in the root folder ( / ) would be a directory or list of directories below the root folder.
I would change the first three from /opt/openhab2 to /opt/openhab3 in case your folder is now named /opt/openhab3 resp. /opt/openhab in case it is now named /opt/openhab.
The fourth one seem to be backup file.
Last one seems not to be mentioned in your log file. That seems to be a comment.
