This issue discusses the design and features of the header of a location card, w…hen not customized by users using slots.
As a semantic card it inherits a number of common properties described in #555 (like background color/image).
## Title
By default, the title is the label of the item (or its name if it has none).
## Subtitle
If the location has a parent, the label or name of the parent is the default (but it should be possible to remove it, for instance if the cards are manually put in groups by the user (see #555).
## At-a-glance modules
The built-in at-a-glance modules (or "complications" as in watch screens) use the semantic model to gather information about the location and display it in a summarized manner with little icons and eventually a short label, "rewarding" the time taken to build a well-designed model by automatically providing information in the header of the card. The goal is not to be exhaustive, rather cover what should be the most popular scenarios. There will still of course be cases outside this anticipated well-known scenarios, and esoteric needs; therefore ideally users should be able to customize these modules, or add more (with slots). It should also be possible to hide automatically shown modules that doesn't work well or aren't desired.
A location card with all modules having something to display should resemble the following example ("worst case scenario"):
It is a little busy, but the average card should be much less so since a module isn't displayed when there is nothing to show.
### General principles for querying data from the model
- Normally the user will have put Equipment in the Locations. Most of these pieces of equipment will have Points. Gathering states from Points is always preferred as opposed to gathering states from Equipment item themselves, but we do it anyway if we couldn't find any matching Point. For instance, for blinds, look for OpenState points in equipment tagged Blinds (the preferred default), but if we can't find any, analyze the state of the Equipment items themselves - and consider a state of OPEN, or CLOSED appropriately.
- In order to leave out any ambiguity about which Points to consider, the admin has the option of relating Points directly to the Location without any Equipment in between. There are many ways to do it:
* a Point can be made a member of both its parent Equipment, and also the Location it's in.
* the item could be duplicated at the Location level and linked to the same channel so that it reflects the same data
* a Group with an aggregation function (e.g. average) can be added as a Point to the Location to compute a state for the location from the state of the desired items.
<br />we should therefore prioritize the results by considering first only the Points which have a direct _hasLocation_ relation to the location; but if none match, we can consider those indirectly related through their equipment items.
### Built-in glance modules
####  Number of alarms (after the title)
__Point_Alarm__ _hasLocation_ __(the location)__
___If no matching item found:___
__Point_Alarm__ _isPointOf_ __(any equipment)__ _hasLocation_ __(the location)__
Count those with the state `ON`: if any result, display the count after the title as shown.
####  Nb. Lights on
__Point_Control*__ _relatedTo_ __Property_Light__ _hasLocation_ __(the location)__ with the state
__Point_Control*__ _relatedTo_ __Property_Light__ _isPointOf_ __(any equipment)__ _hasLocation_ __(the location)__
Count those with the state `ON`, integer>0 or H,S,B with B > 0: single result, display the icon only; multiple results, display the icon and the count.
####  Nb. of Open Windows
__Point_Status_OpenState__ _isPointOf_ __Equipment_Window__ _hasLocation_ __(the location)__
Count those with the state `OPEN`: single result, display the icon only; multiple results, display the icon and the count.
####  Nb. of Open Doors
__Point_Status_OpenState__ _isPointOf_ __Equipment_Door__ _hasLocation_ __(the location)__
####  Nb. of Open Garage Doors
__Point_Status_OpenState__ _isPointOf_ __Equipment_GarageDoor__ _hasLocation_ __(the location)__
####  Nb. of Open Blinds
__Point_Status_OpenState__ _isPointOf_ __Equipment_Blinds__ _hasLocation_ __(the location)__
Count those with the state `OPEN` or integer=0: single result, display the icon only; multiple results, display the icon and the count.
####  Presence Detected
__Point_Status__ _relatedTo_ __Property_Presence__ _hasLocation_ __(the location)__
__Point_Status__ _relatedTo_ __Property_Presence__ _isPointOf_ __(any equipment)__ _hasLocation_ __(the location)__
If any result has the state `ON` or `OPEN`, display the icon.
####  Locks
__Point_Status__ or __Point_Control*__ _isPointOf_ __Equipment_Lock__ _hasLocation_ __(the location)__
If all results have the state `CLOSED` or `OFF`: display
If any result has the state `ON` or `OPEN`: single result, display the icon ; multiple results, display the icon and the count.
####  Climate Control Powered On (A/C, Heating)
__Point_Status__ or __Point_Control*__ __relatedTo_ __Property_Power__ _isPointOf_ __Equipment_HVAC__ _hasLocation_ __(the location)__
If any result has the state `ON`, display the icon.
####  Nb. of Screens Powered On
__Point_Status__ or __Point_Control*__ __relatedTo_ __Property_Power__ _isPointOf_ __Equipment_Screen__ _hasLocation_ __(the location)__
Count those with the state `ON`: single result, display the icon only; multiple results, display the icon and the count.
####  Nb. of Speakers/AV Receivers Powered On
__Point_Status__ or __Point_Control*__ __relatedTo_ __Property_Power__ _isPointOf_ __Equipment_Speaker__ or __Equipment_Receiver__ _hasLocation_ __(the location)__
####  Nb. of Projectors Powered On
__Point_Status__ or __Point_Control*__ __relatedTo_ __Property_Power__ _isPointOf_ __Equipment_Projector__ _hasLocation_ __(the location)__
####  Temperature (Measurement & Setpoint)
##### Measurement part:
__Point_Measurement__ _relatedTo_ __Property_Temperature__ _hasLocation_ __(the location)__
__Point_Measurement__ _relatedTo_ __Property_Temperature__ _isPointOf_ __(any equipment)__ _hasLocation_ __(the location)__
Compute the average of the valid values (if single result, take the result a fortiori), and display if valid.
##### Setpoint part:
__Point_Setpoint__ _relatedTo_ __Property_Temperature__ _hasLocation_ __(the location)__
__Point_Setpoint__ _relatedTo_ __Property_Temperature__ _isPointOf_ __(any equipment)__ _hasLocation_ __(the location)__
There should be only one result in theory; out of an abundance of caution, compute the average of the valid values (if single result, take the result a fortiori), and display if valid between parentheses after the measurement.
####  Humidity (Measurement)
__Point_Measurement__ _relatedTo_ __Property_Humidity__ _hasLocation_ __(the location)__
__Point_Measurement__ _relatedTo_ __Property_Humidity__ _isPointOf_ __(any equipment)__ _hasLocation_ __(the location)__
####  Luminance/Ambient Light (Measurement)
__Point_Measurement__ _relatedTo_ __Property_Light__ _hasLocation_ __(the location)__
__Point_Measurement__ _relatedTo_ __Property_Light__ _isPointOf_ __(any equipment)__ _hasLocation_ __(the location)__
