- openHABian 3.3.0 on rPi4 Raspbian GNU/Linux 11 (bullseye)
I get this error when logging into karaf as openhabian:
/var/lib/openhab/tmp/jansi-2.4.0-e1564dfa7e16a84f-libjansi.so.lck (Permission denied)
In context here:
# [2022-11-15 11:34] openhabian@openhabian /etc/openhab $
openhab-cli console
Logging in as openhab
Password:
_ _ _ ____
___ ___ ___ ___ | | | | / \ | __ )
/ _ \ / _ \ / _ \ / _ \ | |_| | / _ \ | _ \
| (_) | (_) | __/| | | || _ | / ___ \ | |_) )
\___/| __/ \___/|_| |_||_| |_|/_/ \_\|____/
|_| 3.3.0 - Release Build
Use '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
To exit, use '<ctrl-d>' or 'logout'.
Which has been discussed and solved here:
The suggested solution was:
sudo openhabian-config
and then
10 apply improvements
and
14 fix permissions
While this fixed the problem… this lead to another error:
(Half way through it said try again
, which produced the same error)
Visit the development repository for more details: https://github.com/openhab/openhabian
The tool will now restart to load the updates... OK
2022-11-15_13:26:20_AEST [openHABian] Checking for root privileges... OK
2022-11-15_13:26:26_AEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2022-11-15_13:26:26_AEST [openHABian] openHABian configuration tool version: [openHAB3]{2022-11-09T11:29:28+01:00}(1b47639)
2022-11-15_13:26:26_AEST [openHABian] Checking for changes in origin branch openHAB3... OK
2022-11-15_13:28:44_AEST [openHABian] Switching to branch openHAB3... OK
2022-11-15_13:28:45_AEST [openHABian] Adding slightly tuned bash configuration files to system... OK
2022-11-15_13:29:19_AEST [openHABian] Updating Linux package information... OK
2022-11-15_13:35:39_AEST [openHABian] Applying file permissions recommendations... FAILED (openhab folders)
FAILED (folders)
FAILED (unattended upgrades logdir)
FAILED (samba logdir)
FAILED (openhab log)
OK
2022-11-15_16:34:10_AEST [openHABian] Updating Linux package information... OK
2022-11-15_16:34:11_AEST [openHABian] Applying file permissions recommendations... FAILED (openhab folders)
FAILED (folders)
OK
2022-11-15_16:34:19_AEST [openHABian] Checking for default openHABian username:password combination... OK
2022-11-15_16:34:19_AEST [openHABian] We hope you got what you came for! See you again soon ;)
The following screen, referred to this link:
I had a read… I have a standard installation.
The rPi boots, so does openHAB; it just does not write logfiles anymore.
I have not fiddled with anything, just used the UI to config OH3, plus text-based rules.
Now what?
