- Platform information:
- Hardware: _CPUArchitecture/RAM/storage_RPI 4 ARMHF 2GB SSD
- OS: _what OS is used and which version_RASBIAN
- Java Runtime Environment: _which java platform is used and what version_ZULU_11
- openHAB version: openHAB 3.0.1
- Issue of the topic: My old OH2.5.1 Rule does not work after migration to OH3 so i need Help with DSL rules !
I looked around in the Forum to find some answer but all i found does not help understanding the issue.
Thanks for your support…
Mario
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
// Triggers:
// - When homeconnect_CoffeeMaker_SIEMENS_TI9555X1DE_68A40E2D2838_operation_state changed to Finished
// context: HOMECON-1
Thread::sleep(3500)
val COFFEETYPE = SiemensKaffeevollautomat_SelectedProgram.split(’\.’).get(4)
logInfo(“SayCOFFEETYPE”, COFFEETYPE )
var String AUSWAHL
AUSWAHL=COFFEETYPE
var String SayText
SayText=“Dein “+ AUSWAHL +” ist fertig !”
logInfo(“SayCOFFEETYPE”, “SayText: {}”,SayText)
amazonechocontrol_echo_e09dae9e_G090LF09650409CH_textToSpeech.sendCommand(SayText)
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
2021-04-11 12:31:55.588 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘HOMECON-1’ failed: ‘split’ is not a member of ‘org.openhab.core.library.items.StringItem’; line 6, column 19, length 53 in HOMECON
