I am new to OpenHub 3 and I did not use openhub 2.
I would like to read my electricity meter with openhub.
In connection with the SmartMeter, I also get some values displayed, but not all.
The whole thing runs on a PI with IR on USB.
The log file (var / log / openhab / openhab.log) shows the following values
Thanks for the answer
I have created a smart meter under thinks, which also shows me all available channels.
I think the channel is once a string, whenever it is NULL
and Number: ElectricPotential whenever a value is supplied.
Unfortunately I didn’t find a way to adjust the settings in the channel
Things
1-0:1.8.0255
1-0_1-8 -0_255 (String)
Value for OBIS code: 1-0:1.8.0255 with Unit: null
Item
1-0:1.8.0*255 String . Point
SmartMeter_10180255 NULL
Things
1-0:2 1.7.0255
1_0_21-7-0_255 (Number:Power)
Value for OBIS Code 1-0:21.7.0255 with Unit: W
Item
1-0:21.7.0*255 Number:Power · Point
SmartMeter_1021170255 959.00W
I installed smartmeter binding but didn’t use it, I have to see how it works
Dear Tuny,
thanks for the answer, it helped a lot.
The values are now displayed.
I had already experimented a little with the Fritzbox and the google calendar, but the items were always ready after the installation, so I never got the idea to create one myself (beginner).
Thanks again to all the helpers.
I was looking for a manual for smart meters and this obis conversion, since it looked similar to you in the screenshot, I was hoping to see how the page could look like (ideas for designing).
In the meantime I have established that open hab has a lot of possibilities and you have read the documentation, there is a lot in it, so rtfm
Sorry for my english, but the google translator helps me.
Many Thanks
