Can somebody guide me to the menu where to activate the dark mode ?
And i’m not sure if it is a bug or just me, but the icons for my lightbulbs are not changing with the state of the switch (grey when OFF and yellow when ON)
As the new UI is accessed as webapp, it is one web client per device, so setting for each device individually.
MDAR
7
Hi
I’m not sure if this is the correct place to put this observation, so if not I’m happy to start a new thread.
I am test driving OH3 and so far things are going well, with just a strange observation / bug.
When using HabPanel in OH3 I can place and edit any of the built in widgets, but if I import a widget I can’t edit it to add the Item data.
(The Widget design editor seems to be fine)
MDAR
9
Hi
Yeah, the same way I have been with OH2’s HabPanel
MDAR
10
Hi
I’ve just had a quick play around again.
So yes,
I imported the widget the traditional way and can place it in the design / layout for each dashboard panel, but clicking on the Edit option (top right corner, along with Copy & delete) does nothing.
If I edit the JSON file in the HabPanel editor, the widget works perfectly.
(When I know which instance of the widget is which)
