It does but you didn’t pay attention to the units.
(Thanks for pointing this out.)
Anyone any ideas what to change to get rid of the OH log errors WRT influx.
Influx was install via the client tool, but not configured in OH as a persistence service.
When I reinstalled openhabian w/o influx, restoring the OH backup from the previous system that had influx, it came up with the same errors.
Hence, why this tome, I want to fix it.
I did delete the services/influxdb.cfg.
I better create a new post.
You gotta remove the InfluxDB add-on from openHAB so it stops trying to connect to an instance that doesn’t exist.
If OH knows anything at all about InfluxDB, it means the InfluxDB add-on is installed. It may just have a default configuration but the default configuration will still have it attempting to connect.
