Number tmpStudy { channel="onewire:basic:383a75c6:28_984CDE030000:temperature",
channel="knx:device:bridge:DEV203:Ch203F_ist" [profile="follow"]
which sends temperature update from onewire to knx as expected.
In OH3 I made the same config through the GUI and set the follow property for the link to the knx channel. The item gets updates nicely from onewire, but nothing is forwarded to knx.
The KNX channel channel is defined as “number” (tried number-control also) with the right Group Address. All other KNX channels work perfectly.
Thanks for your reply.
Actually I have it as a number and still cannot see OH being able to send any data over KNX bus via this channel. The Input value coming from KNX bus updates the item without any issues.
Yes I do. It does not come out of the KNX bridge. It seams it is a conversion problem when linking homekit temp item to KNX nubmer item. When I send any explicit value via rule it works.
