Thanks for adding the Wan Block to the new OH3 binding
I finally switched to OH3 and I am now testing …
I added an IP to the parameters for the Thing.
I tried to Scan again but no new SubDevice did show up and neither a new channel for blocking this IP came up in an existing Device.
Am I looking at the wrong place or anything I need to do after adding an IP to the WanBlock section?
Ok - its not very special.
The Box itself is working and other channels are linked to items and work fine.
In the Wan Block IPs I added one IPv4 to test (it does exist on the network)
The Channels of the device don’t show anything new after I added it.
Also the channels of the subdevices don’t have a new channel.
Unfortunately I can’t test that: Channel wanBlockByIP not available: Service 'urn:X_AVM-DE_HostFilter-com:serviceId:X_AVM-DE_HostFilter1' not found on my system. What is in the log for you?
14:50:02.527 [DEBUG] [nhab.binding.tr064.internal.util.Util] - Channel wanBlockByIP not available: Could not get required parameter for channel 'wanBlockByIP' from thing config (missing, empty or invalid)
sorry … one more question while I still hope that the above issue can be solved
while fiddeling with that Wan Block and other features like MAC Online I also asked myself if there is a way I could “comment” an IP or Mac in the parameter…
Otherwise this is hard to “maintain” for a user…
I mean instead of:
So channels work and I added a Switch Item to that channel.
Unfortunately when I use the switch I see:
13:43:26.303 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'FBOX_WANBlock1' received command ON
13:43:26.306 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'FBOX_WANBlock1' predicted to become ON
13:43:26.309 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FBOX_WANBlock1' changed from UNDEF to ON
13:43:26.312 [DEBUG] [ing.tr064.internal.soap.SOAPConnector] - Sending ON as 1 to urn:X_AVM-DE_HostFilter-com:serviceId:X_AVM-DE_HostFilter1/DisallowWANAccessByIP
13:43:26.325 [WARN ] [ing.tr064.internal.soap.SOAPConnector] - Could not send command ON: HTTP-Response-Code 500 (Internal Server Error), SOAP-Fault: 402 (Invalid Args)
so it says UPNP error… I can retry with allowing UPNP in the FB … however I would not like UPNP standard to be turned on. EDIT: Enabling UPNP in the FB does not help. same error.
Also maybe a “switch item” is wrong? As the “Kindersicherung” can have more states.
I uninstalled the former on the shell and dropped the new one in the addons folder
should it still read a yesterday date?
288 │ Active │ 80 │ 3.1.0.202101021630 │ org.openhab.binding.tr064
if this is the correct one I still see:
14:12:53.433 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'FBOX_WANBlock1' received command ON
14:12:53.444 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'FBOX_WANBlock1' predicted to become ON
14:12:53.450 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FBOX_WANBlock1' changed from UNDEF to ON
14:12:53.455 [DEBUG] [ing.tr064.internal.soap.SOAPConnector] - Sending ON as 1 to urn:X_AVM-DE_HostFilter-com:serviceId:X_AVM-DE_HostFilter1/DisallowWANAccessByIP
14:12:53.460 [TRACE] [ing.tr064.internal.soap.SOAPConnector] - Request: <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Header/><SOAP-ENV:Body><u:DisallowWANAccessByIP xmlns:u="urn:dslforum-org:service:X_AVM-DE_HostFilter:1"><NewDisallow>1</NewDisallow><NewIPv4Address>192.168.1.84 #IPCamGarten</NewIPv4Address></u:DisallowWANAccessByIP></SOAP-ENV:Body></SOAP-ENV:Envelope>
14:12:53.472 [TRACE] [ing.tr064.internal.soap.SOAPConnector] - Received response: <?xml version="1.0"?>
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<s:Body>
<s:Fault>
<faultcode>s:Client</faultcode>
<faultstring>UPnPError</faultstring>
<detail>
<UPnPError xmlns="urn:dslforum-org:control-1-0">
<errorCode>402</errorCode>
<errorDescription>Invalid Args</errorDescription>
</UPnPError>
</detail>
</s:Fault>
</s:Body>
</s:Envelope>
14:12:53.476 [WARN ] [ing.tr064.internal.soap.SOAPConnector] - Could not send command ON: HTTP-Response-Code 500 (Internal Server Error), SOAP-Fault: 402 (Invalid Args)
