I am using last few weeks these devices:
It supported by zigbee2MQTT current version 1.7 and listed as “TS0601_thermostat”.
If you have OH3 and MQTT installed, manually add Generic MQTT Thing add copy to “Code” tab YAML code with configuration of channels:
label: TRV1
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:ohpi2
- id: CurrentHeatingSetpoint
channelTypeUID: mqtt:number
label: Temperature Target
description: ""
configuration:
unit: °C
min: 5
formatBeforePublish: '{"current_heating_setpoint": %.1f}'
max: 35
commandTopic: zigbee2mqtt/TRV1/set
step: 0.5
stateTopic: zigbee2mqtt/TRV1
transformationPattern: REGEX:(.*\"current_heating_setpoint\".*)∩JSONPATH:$.current_heating_setpoint
- id: linkquality
label: Link Quality
description: null
configuration:
transformationPattern: REGEX:(.*\"linkquality\".*)∩JSONPATH:$.linkquality
unit: lqi
- id: LocalTemperature
label: Local Temperature
description: null
configuration:
transformationPattern: REGEX:(.*\"local_temperature\".*)∩JSONPATH:$.local_temperature
unit: °C
- id: position
label: Valve Position
description: ""
configuration:
min: 0
transformationPattern: REGEX:(.*\"position\".*)∩JSONPATH:$.position
max: 100
- id: SystemMode
channelTypeUID: mqtt:string
label: System Mode
description: ""
configuration:
allowedStates: heat,auto,off,manual
formatBeforePublish: '{"system_mode": %s}'
transformationPattern: REGEX:(.*\"system_mode\".*)∩JSONPATH:$.system_mode
- id: preset
label: Preset
description: ""
configuration:
allowedStates: manual,complex,schedule,boost,comfort,eco
formatBeforePublish: '{"preset": %s}'
transformationPattern: REGEX:(.*\"preset\".*)∩JSONPATH:$.preset
- id: childlock
channelTypeUID: mqtt:switch
label: Child Lock
description: ""
configuration:
formatBeforePublish: '{"child_lock": "%s"}'
transformationPattern: REGEX:(.*\"child_lock\".*)∩JSONPATH:$.child_lock
off: UNLOCK
on: LOCK
- id: BatteryLow
channelTypeUID: mqtt:contact
label: Battery low
description: ""
configuration:
transformationPattern: REGEX:(.*\"battery_low\".*)∩JSONPATH:$.battery_low
off: "false"
on: "true"
- id: autolock
label: Auto Lock
description: ""
configuration:
transformationPattern: REGEX:(.*\"auto_lock\".*)∩JSONPATH:$.auto_lock
- id: awaymode
label: Away mode
description: ""
configuration:
commandTopic: zigbee2mqtt/TRV1/set/away_mode
transformationPattern: REGEX:(.*\"away_mode\".*)∩JSONPATH:$.away_mode
off: '"OFF"'
on: '"ON"'
- id: local_temperature_calibration
label: Temperature calibration
description: ""
configuration:
unit: °C
min: -3
max: 3
commandTopic: zigbee2mqtt/TRV1/set/local_temperature_calibration
step: 0.5
transformationPattern: REGEX:(.*\"local_temperature_calibration\".*)∩JSONPATH:$.local_temperature_calibration
- id: away_preset_days
label: Away Preset Days
description: ""
configuration:
commandTopic: zigbee2mqtt/TRV1/set/away_preset_days
unit: days
min: 1
transformationPattern: REGEX:(.*\"away_preset_days\".*)∩JSONPATH:$.away_preset_days
max: 30
- id: away_preset_temperature
label: Away Preset Temperature
description: ""
configuration:
commandTopic: zigbee2mqtt/TRV1/set/away_preset_temperature
unit: °C
min: 5
transformationPattern: REGEX:(.*\"away_preset_temperature\".*)∩JSONPATH:$.away_preset_temperature
max: 25
- id: boost_time
label: Boost time
description: ""
configuration:
unit: s
min: 100
max: 900
commandTopic: zigbee2mqtt/TRV1/set/boost_time
step: 100
transformationPattern: REGEX:(.*\"boost_time\".*)∩JSONPATH:$.boost_time
- id: comfort_temperature
label: Comfort temperature
description: ""
configuration:
commandTopic: zigbee2mqtt/TRV1/set/comfort_temperature
unit: °C
min: 5
transformationPattern: REGEX:(.*\"comfort_temperature\".*)∩JSONPATH:$.comfort_temperature
max: 35
- id: eco_temperature
label: Eco temperature
description: ""
configuration:
commandTopic: zigbee2mqtt/TRV1/set/eco_temperature
unit: °C
min: 5
transformationPattern: REGEX:(.*\"eco_temperature\".*)∩JSONPATH:$.eco_temperature
max: 25
- id: force
label: Force
description: ""
configuration:
allowedStates: open,close,normal
formatBeforePublish: '{"force":"%s"}'
transformationPattern: REGEX:(.*\"force\".*)∩JSONPATH:$.force
- id: window_detection
label: Window detection
description: ""
configuration:
formatBeforePublish: '{"window_detection":"%s"}'
transformationPattern: REGEX:(.*\"window_detection\".*)∩JSONPATH:$.window_detection
off: OFF
on: ON
- id: week
label: Week
description: ""
configuration:
allowedStates: 5+2,6+1,7
formatBeforePublish: '{"week":"%s"}'
transformationPattern: REGEX:(.*\"week\".*)∩JSONPATH:$.week
- id: LastSeen
channelTypeUID: mqtt:datetime
label: Last Seen
description: ""
configuration:
transformationPattern: REGEX:(.*\"last_seen\".*)∩JSONPATH:$.last_seen
You may need to edit commandTopics and stateTopics to reflect your settings.
There is additional topics “work days” and “holiday” schedules, but I can’t find the good way to configure them yet. Would be great if some one can share these channels settings.
Hope this data are useful and will save time.
Update: added channel LastSeen - contains date/time of last Zigbee message from device.
