I am gradually transitioning from text based to UI in OpenHAB3 but I do not find a way to create from the UI the following group (which works in textual definitions)
Group:Number:COUNT("ControlledOff") gENEL_shred "number of Shred equipments"
The members of the group are string items. When I try to import from text definition it gives an error
Error: Syntax error at line 1 col 20:
Unexpected string token: "ControlledOff". Instead, I was expecting to see one of the following:
A identifier token based on:
AggArgs → "(" ● %identifier _ "," _ %identifier ")"
Type → "Group" %membertype ":" %aggfunc ● AggArgs
Item → ● Type _ Name Label Icon Groups Tags Metadata
Items → ● Item
Main → _ ● Items _
AggArgs → "(" ● %identifier ")"
Items → ● Item
Main → _ ● Items _
If I try to create the group from the UI, I am not able to obtain the COUNT aggregation function.
What am I doing wrong?
Thank you for your attention
