Is there any way to use the “Developer Sidebar” using variables from a widget under development?
It seems that only items can be accessed, which means that expressions such as
="partition_secondary_command|2," + (1 << (((vars.selectedPartition === NULL) ? props.selectedPartition : vars.selectedPartition).substr(-1) - 1))
Can not be evaluated?
If not - any suggestions on how to evaluate / debug this expression?
I am trying to understand the syntax and adapt to my uses.
Mark
