Having trouble with the Ademco Binding for OH3 when trying to disable Chime Mode.
The odd thing is that ChimeMode can be enabled with the binding just fine. So it leads me to question is the correct command being sent by the binding?
Below is the debug output. The on command receives an ACK where as the off never does and the state never changes:
Item ‘Partition1_PartitionChimeMode’ changed from ON to OFF
14:15:10.365 [DEBUG] [ternal.handler.PartitionBridgeHandler] - Sending XXXX1
14:15:10.365 [DEBUG] [ernal.handler.EnvisalinkBridgeHandler] - write(): “12341”
14:15:10.366 [DEBUG] [ernal.handler.EnvisalinkBridgeHandler] - Wait For ACK
14:15:10.830 [DEBUG] [ernal.handler.EnvisalinkBridgeHandler] - read(): “%00,01,1C28,08,00, DISARMED CHIME Ready to Arm $”
14:15:10.831 [DEBUG] [ernal.handler.EnvisalinkBridgeHandler] - Command 0 received
14:15:10.831 [DEBUG] [ernal.handler.EnvisalinkBridgeHandler] - got input 01,1C28,08,00, DISARMED CHIME Ready to Arm
14:15:10.832 [DEBUG] [ternal.handler.PartitionBridgeHandler] - Decoding lastMessage: DISARMED CHIME Ready to Arm
14:15:10.832 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Partition1_PartitionChimeMode’ changed from OFF to ON
I’m getting this now with the 3.4 version vs. the 3.2 version I had running.
I’m running OH 3.2, not sure if that is the issue or not? I did restart OH from scratch.
2022-10-13 07:39:23.647 [WARN ] [ng.ademco.internal.handler.EnvisalinkBridgeHandler] - No pulse seen for the last 1 minutes
2022-10-13 07:40:28.649 [WARN ] [ng.ademco.internal.handler.EnvisalinkBridgeHandler] - No pulse seen for the last 1 minutes
Can someone re-compile the Ademco binding against the 4.x framework? I finally upgraded to OH 4.x and the binding doesn’t work now. All the Things are online but OH can’t talk to the unit because of this issue below.
2023-11-17 22:08:08.363 [WARN ] [ng.ademco.internal.handler.EnvisalinkBridgeHandler] - No pulse seen for the last 1 minutes
2023-11-17 22:09:13.364 [WARN ] [ng.ademco.internal.handler.EnvisalinkBridgeHandler] - No pulse seen for the last 1 minutes
2023-11-17 22:10:18.366 [WARN ] [ng.ademco.internal.handler.EnvisalinkBridgeHandler] - No pulse seen for the last 1 minutes
Hey Jay - I believe you should be using the currently supported binding Alarm Decoder for a vista20p. This is what I use and it is built in / working with openhab 4.0. Hope that helps.
