OH3: Volume control „Master“ is missing
I started a ticket on github:
https://github.com/openhab/openhab-distro/issues/1237
bash scripts are also not working. same to you?
currently investigating in this problem…
seems that openhabian 1.6.2 is a little bit buggy…
To be honest, it isn’t verry stable in my opinion. but maybe i’m doing some things wrong.
Im struggling a lot since upgrade at least.
Bash is working for me by the way. I use it as : executeCommand(“bash”,“somefile.sh”) > and added it to the whitelist without bash.
But as now I experience:
  • Logtail is gone after restart openhab > have to reinstall it every time via openhabian-config
  • Google Cloud TTS doesn’t work after reboot (just hear noise or nothing), this was a part of the problem above, i thought it was the sound config, but it was both…
  • executeCommand doesn’t show anything in the log
are bash scripts working from command line?
Yup, i have a simple script to read a folders contents. Tried it just now and it works. doesn’t bash work at your installation?
not from command line. I need to run each script with bash scriptfile.sh instead of scriptfile.sh
sorry, did not understand you meant with bash in front of it. Yeah i need to run with bash in front of it:
[15:30:19] openhabian@openHABianDevice:/var/lib/openhab$ bash loc.sh
  7504 total
[15:30:22] openhabian@openHABianDevice:/var/lib/openhab$ loc.sh
-bash: loc.sh: command not found
ok - same to you again. I start another thread for this. don’t know what to do here.
and thanks for double checking
For your volume issue, no. For others, yes.
Having similar issues, OH3 fresh install, Raspberry Pi 4. The command line:
amixer sset Headphone 100%
worked, and I have sound now, but still get this warning:
[WARN ] [nternal.javasound.JavaSoundAudioSink] - Cannot determine master volume level - assuming 100%
My audio device also reports that is it Mono.
Take
"enhancedjavasound"
out! that at least for me fixed the problem.
Not sure why it is needed at all.
enhancedjavasound has mp3 support.
However, openhab:audio sinks shows that enhancedjavasound is available
I took “enhancedjavasound” out, the error “Cannot determine master volume level - assuming 100%” still appears.
Using executeComman is only a nice workaround.
A real solution would be nice. I think it should work with openhabian on standard hardware (pi4).
is there any progress…having the same error log in OH3 since migration. Annoying as definitely there needs to be something changed…but what.
It completely ignores my: setMasterVolume(new PercentType(60))
and goes out with 100% + Error Warning like mentioned many times above…
I, too, am suffering from this error
Whenever a rule calls for a sound to play. Rule written in MainUI with .mp3 file hosted on the Raspi4 and sink as ‘System Speaker’ volume at 100. Raspi-config audio setting pointed at headphones. Audio jack to speaker - never heard a sound
Anybody knows solution?
