recently I upgraded from openhab 2.4 to 3.0. So far so good after fixing a lot of issues I’m still struggling with the web ui. Both on iOS as well as on MacOS the switches are not working properly.
Whenever I try to switch the light on it’s switching back to off automatically. Is this an issue related to Safari? What can I do to fix it? Tweaking my sitemap?
well I was lacking some information. The lights are not switching ON/OFF at all. I try to switch my lights the switch in BasicUI is flipping back to OFF again. Although in the log file I can see that the event was triggered. I guess these are two issue. But why is the BasicUI not behaving as expected in Safari?
Any clues?
Thanks, Manuel
Alright, that’s a clue hat maybe the command has not worked at all. In which case the UI might be telling you the truth - your Item is still OFF after a failed attempt to turn ON.
Shame on me
I changed the knx config recently which caused a connection loss to my knx IP interface.
Now I’ve commented almost every line…and it’s working again.
That’s my new config now:
// TUNNEL
Bridge knx:ip:bridge [
type=“TUNNEL”,
ipAddress=“10.0.55.12”
// portNumber=3671
// localIp=“10.0.55.5”,
// readingPause=50,
// responseTimeout=10,
// readRetriesLimit=3,
// autoReconnectPeriod=60,
// localSourceAddr=“0.0.0”
Thing device generic [
// address=“1.2.2”,
// fetch=true,
// pingInterval=300,
// readInterval=0
// WINDOWS AND DOOR CONTACTS
Many thanks…I guess it should work now. For other issues I’ll open a separate thread.
Cheers
