OH3 Where is Frontail and Paper UI
Paper UI has been replaced with the new Main UI. Use this to configure your setup. And you need to install frontail manually if you dont use openhabian, otherwise look for installation options in openhabian config.
That’s unfortunate. The best part of paper UI was that it would automatically configure the items making it easy to see if a device is working or updating. Is there anyway to automate the Main UI? As far as I can tell each item must be manually added.
As for Frontail, I am using openhabian and it was installed when I was using OH2. Where can I go to access the logs from the OH3 dashboard?
I found a fix for the frontail problem. After reinstalling it through openhabian-config (21), it can be accessed through: http://openhabiandevice:9001. AFAIK there is no link to it in the openHAB 3 dashboard. Guess I just gotta bookmark it.
Automatic Item generation:
Afaik this has been removed in the new UI because it had several negative impact.
About 80% of the Threads regarding “Paper UI simple mode” recommended to deactivate it.
About the bookmark:
You could use your DAshboard page for this and ad a Label with an external URL.
Example:
Example yaml for the Pages config:
component: oh-label-card
  action: url
  actionUrl: http://openhabiandevice:9001/
  label: Frontail
  footer: Open in new Tab
MainUI’s replacement for the Control tab in PaperUI is the Overview Page and unlike PaperUI, it actually works as a UI. But it requires a little more work on your part. What you’ll want to do is:
From the Model Page click on “create equipment from Thing”. Select your Thing and then select the Channels you care about. Then you have the option to set the settings for the Items (e.g. name, semantic tags, etc) and when you click create it will create all those Items.
You can also create the equipment from Thing from the Thing’s page.
Anything that is part of the model will have UI elements created in the locations, equipment, and properties tab of the Overview Page. And if you don’t like how they are shown, you can actually change it.
PaperUI’s automatic Item creation was half a step away from a complete disaster. Pretty much everyone grows out of it pretty fast and then they have to go and undo everything auto Item creation has done, sometimes with a result of breaking things.
There really isn’t a dashboard in OH 3. There is MainUI.
In the UI I think it’s called the Overview page, right?
Correct. I have to learn the neww terms too sorry. :smiley:
In generyl, there should be a possibility to add frontail to the other apps (tiles) menu, as habbot is added there after installation.
@ysc did you have a chance to check where this config is hidden?
@hmerk I have already created an issue in openhab-core. See here and here.
But there was no reaction from the openhab-core/maintainers.
It’s a MainUI issue, not openhab-core. Frontail isn’t actually part of openHAB. It’s a third party service. So the issue is enabling (if not already possible) and showing how to add other external URLs to the list in the little menu at the upper right hand of the MainUI.
@ysc has moved the issue from openhab-webui to openhab-core because the call to addTilesForExternalServices is missing in openhab-core.
The service has been renamed from org.openhab.dashboard to org.openhab.core.ui.tiles, guess I meant to check how that translated in terms of where/how that configuration should end up but forgot. Provided it can still be done, without a change to the code, and someone finds where to configure it you’ll be able to add your links and they will appear in the other apps drawer. Can’t check myself until after Christmas or the new year.
You made me pull out my laptop… probably for the last time today :wink:
in services/runtime.cfg:
org.openhab.core.ui.tiles:myopenhab-link-name=myopenHAB
org.openhab.core.ui.tiles:myopenhab-link-url=https://www.myopenhab.org
org.openhab.core.ui.tiles:myopenhab-link-imageurl=https://www.myopenhab.org/images/hero.jpg
Thank you!
So for a default openHABian installation it would be:
org.openhab.core.ui.tiles:openhabiandocs-link-name=openHABian Help
org.openhab.core.ui.tiles:openhabiandocs-link-url=https://www.openhab.org/docs/installation/openhabian.html
org.openhab.core.ui.tiles:openhabiandocs-link-imageurl=data:image/png;base64,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
org.openhab.core.ui.tiles:frontail-link-name=openHAB Log Viewer
org.openhab.core.ui.tiles:frontail-link-url=http://{HOSTNAME}:9001
org.openhab.core.ui.tiles:frontail-link-imageurl=data:image/png;base64,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
{HOSTNAME} has to be replaced with the real hostname, this is not done automatically like it was in the dashboard.cfg
But this is only a minor inconvenience. Great it works :slight_smile:
// Update: I discovered that to remove accidentally added tiles you need to empty them (not remove!) like:
Thanks for the hint. By the way, after adding a link you can not remove it again. Even if you remove it from the runtime.cfg the link will be still available. I made some research and found the new location of the link. After adding the first link a new file file will be created where the links will be stored.
The file can be found here: userdata\config\org\openhab\core\ui\tiles.config
Edit: After some more testing I can confirm that the path i posted there can be used for removing the link again. So you need to remove it in the runtime.cfg and the tiles.config. But if you want to modify the link this has to be done in runtime.cfg. A change in tiles.config is not updating the webui config. I’m not sure if this is the expected behavior but at least it works :wink:
Thanks for the investigation. Something to improve in 3.1 probably.
By the way these “other apps” are accessible to every user so for things that aren’t meant to non-admins it might be better to provide something that will add menu entries in Settings / Dev tools instead.
Thanks guys, I was able to successfully add new tiles for Frontail and Grafana for now, will try to remember what else I had on my 2.5 install, and add those later. The new interface is going to take some learning, so will have to set some time to go over all the new UI.
I’ve read this thread and added some tiles to services/runtime.cfg and restarted OH3. But where do I find them now? I looked around everywhere in the UI but I’m not able to spot those tiles? Do I have to add them manually somehow somewhere? Feel quite like a noob atm. This new interface is really challenging atm.
On the main page of openHAB have a look on the upper right section. You can find a button which opens a menu with all other UI’s and your external links.
Ahh, thank you so much!
Thanks everyone :smile:
Not a fix as flexible as using {HOSTNAME} but I have just used the Host Name of the machine
cat /etc/hostname
