Java Runtime Environment: openjdk version “11.0.9”
openHAB version: 3.0.0
Issue of the topic:
I am wondering how to figure out which commands are available for an Item.
In this example for my Xiaomi Vacuum Control I would like to label the commands for my sitemap.
The problem is, I don’t know the available commands.
My guess was I can check it from the Item itself, which shows the following options:
This results in an error in the Sitemap:
Error: Syntax error at line 2 col 138:
Switch icon="switch" label="Befehle" item=ArchyXiaomiMiRoborock_ControlVacuum mappings=[Vacuum="Start",Pause="Pause",Dock="Dock",Spot
Unexpected WS token: " ". Instead, I was expecting to see one of the following:
The space of the “Spot Clean” causes the error. The problem is that I still don’t know the available commands.
If manually editing sitemap files, you’d use quotes
… mappings=[Vacuum=“Start”,“Spot Clean”=“whatever”, …
Don’t know what you do in UI editing, you could try just that, quote marks.
