Hi All
I am trying to replicate an alarm keypad (as close as possible) within a Custom Widget.
One of the indicator lights should flash when the panel is in “Exit Delay”, so the three status conditions would be:
ON: - red
OFF: - gray
FLASHING: - flashing between red and gray
My code so far looks as follows:
- component: f7-badge
bgColor: '=(items.Panel_ACPowerOn.state === "ON") ? "red" : "gray"'
style:
border-radius: 20px
height: 20px
left: 10px
position: absolute
top: 240px
width: 25px
I am however not able to find a way to implement the FLASHING condition.
Does anyone have a solution/suggestion that I can try?
Thanks Justin. As usual you pointed me in the right direction. Once I used the correct terminology I was able to find an example to use to get the animation part to flash the colours and your linked example helped me construct a working basic widget as follows:
uid: Test_Colour_Animation
tags: []
props:
parameters:
- description: A text prop
label: Prop 1
required: false
type: TEXT
- context: item
description: An item to control
label: Item
required: false
type: TEXT
parameterGroups: []
timestamp: Dec 22, 2022, 5:39:15 PM
component: f7-page
stylesheet: >
.myDIV {
animation: mymove 1s infinite;
} @keyframes mymove {
from {background-color: orange;}
to {background-color: gray;}
slots:
default:
class: myDIV
style:
border-radius: 20px
height: 20px
left: 10px
position: absolute
top: 240px
width: 25px
Giving:
Please can you point me in a direction now to be able to base the colour on an expression.
You cannot use expressions in the stylesheet. What you have to do is put a style object in the same config and set a css variable in that object, which you can do with an expression.
style:
--blink-color1: red
--blink-color2: yellow
And then you can reference that variable in the stylesheet
stylesheet: >
.myDIV {
from {background-color: var(--blink-color1);}
to {background-color: var(--blink-color2);}
Thanks Justin. Maybe I was not clear on what I needed, but you have helped me solve it anyway.
My working code:
tags: []
props:
parameters:
label: Prop 1
required: false
type: TEXT
- context: item
label: Item
required: false
type: TEXT
parameterGroups: []
component: f7-page
stylesheet: >
.paradoxFlash {
animation: mymove 0.5s infinite;
from {background-color: green;}
to {background-color: orange;}
.paradoxOrange {
background: orange
.paradoxGray {
background: gray
slots:
default:
class: '=(items.ParaTest1.state === "ON") ? "paradoxFlash" : (items.ParaTest2.state === "ON") ? "paradoxOrange" : "paradoxGray"'
style:
border-radius: 20px
height: 20px
left: 10px
position: absolute
top: 240px
width: 25px
So when Paratest1 is ON (regardless of Paratest2), get paradoxFlash, when Paratest2 in ON (only if Paratest1 is OFF), get paradoxOrange and when neither ON, get paradoxGray.
Yes and no. I’ve never looked into the details of how the stylesheet is implemented, but there does appear to be some matter of timing. If you were to change the selector in your sheet from .background to div, I think you would find that it works. But it seems that the f7 classes, and any classes you apply manually are added to the element after the stylesheet is processed, so selectors based on class (or id for that matter) won’t work on the same level as the stylesheet.
The easy solution for you here is to make an f7-block the base component of the element and put the stylesheet at that level and then make the card a child of that block.
I managed to got it working with your first suggestion (using div selector) but failed to get it working with the second tip. This latter solution also creates a lot of other problems for me and the layout.
Now the next problem I have is that this stylesheet property in the widget does not get parsed (at least it seems so) and therefore I cannot create an animation based on an object status.
What I want is a background color ‘off’ (white) when my alarm status is 0. A color ‘on’ (green) when my alarm status is 2 and flashing white/green when it has status 1.
My final workaround is some SVG (1 ‘pixel’) from which one has animation and then use the background property.
See the post above for how to make the stylesheet dynamic:
It sounds like it might just make more sense to do this is classes. Those are easily added to components with expressions. So create the flashing animation with a particular class name in the stylesheet at the very top level of the widget and then just apply the class if the given condition is met.
