OH3 Widget Multi Sensor (Fibaro/Aeon/Philio/Aeotec)
Tags: #<Tag:0x00007fc8f62df458> #<Tag:0x00007fc8f62df138> #<Tag:0x00007fc8f62df070>
Here is my first effort at a widget for OH3. It was designed to support the Fibaro motion sensor that provides 5 items, but could easily be adapted to any application where a thing provides a number of items to display.
Design objectives
  • Display a number of items. If possible, be an extensible design to support as many items as needed for other devices.
  • Function and look good on laptop and mobile screens. Be touch compliant on small screens.
  • Be flexible to allow the display of all or some of the items supported by the device.
  • Support easy format customisation (I’m not sure on my overall theme design as yet).
  • Conditionally highlight icons that require user attention e.g. when the battery level matches or is below a specified threshold.
  • Allow drill down to the default widget / graph associated with each item.
I took inspiration from with work on the UI Widget: Weather, specifically the card widget by @RGroll and @oh11. In particular their use of the Swiper component provided a good solution the screen size/resolution issues. Their solution was a great way to start learning the new UI.
Here is the result:
Large screen showing all items being displayed.
Fibaro_small
Small screen showing swiper functionality to access icons that don’t fit on screen.
So the final feature set / some useful stuff I learnt:
  • Most of the features listed in the objectives above (maybe a better solution for extensibility).
  • Support for background / font / icon colour selection based on theme and/or any of the HTML colour standards (RGB/RGBA/HEX/HSL). Note you must specify the full format rgba(0,0,0,0) etc.
  • How to add an external link within the parameter description to access relevant reference materials.
  • How to drill down to display analyser data for each item.
Things that could be better/improved:
  • In portrait mode on small screens swiping arrows overlap the buttons, requiring careful clicking (or the analyzer graphs are displayed for the icon. Not so easy with my fat fingers :stuck_out_tongue_winking_eye: Need to experiment with the swiper padding options.
  • Avoided a repeater as data types (number / text), warning conditions and icons are different for each item. May be worth looking into now I have learnt more :wink:
Here is the YAML:
uid: fibaro_motion_card
tags: []
props:
  parameters:
    - context: item
      description: Name of the item containing motion sensor data. If undefined will not display the associated icon/text.
      label: Item Name (Motion sensor)
      required: false
      type: TEXT
      groupName: items
    - context: item
      description: Name of the item containing temperature sensor data. If undefined will not display the associated icon/text.
      label: Item Name (Temperature sensor)
      required: false
      type: TEXT
      groupName: items
    - context: item
      description: Name of the item containing light sensor / luminescence data. If undefined will not display the associated icon/text.
      label: Item name (Light sensor)
      required: false
      type: TEXT
      groupName: items
    - context: item
      description: Name of the item containing accelerometer / tamper alarm data. If undefined will not display the associated icon/text.
      label: Item name (Accelerometer sensor / Tamper alarm)
      required: false
      type: TEXT
      groupName: items
    - context: item
      description: Name of the item containing battery charge level data. If undefined will not display the associated icon/text.
      label: Item name (Battery level)
      required: false
      type: TEXT
      groupName: items
    - description: Highlight the motion sensor icon/text when the value equals the specified warning value e.g. ON. When undefined, no highlighting is displayed.
      label: Warning (Motion sensor)
      required: false
      type: TEXT
      groupName: warn
    - description: Highlight the temperature icon/text when the value is LESS than the specified warning value e.g. 10. When undefined, no highlighting is displayed.
      label: Warning (Temperature sensor)
      required: false
      type: TEXT
      groupName: warn
    - description: Highlight the light sensor icon/text when the value is LESS that the specified warning value e.g. 5. When undefined, no highlighting is displayed.
      label: Warning (Light sensor)
      required: false
      type: TEXT
      groupName: warn
    - description: Highlight the tamper alarm icon/text when the value equals the specified warning value item e.g. ON. When undefined, no highlighting is displayed.
      label: Warning (Accelerometer sensor / Tamper alarm)
      required: false
      type: TEXT
      groupName: warn
    - description: Highlight the battery level icon/text when the value is LESS than the specified warning level e.g. 15. When undefined, no highlighting is displayed.
      label: Warning (Battery level)
      required: false
      type: TEXT
      groupName: warn
    - description: Set card header title. Only displays if populated.
      label: Card Title
      required: false
      type: TEXT
      groupName: general
    - description: Background image URL e.g. http://10.1.0.1/static/fibaromotion.png
      label: Background image URL
      required: false
      type: TEXT
      groupName: general
    - description: Intensity of the background-blur (0 - 10)
      label: Background image blur
      required: false
      type: TEXT
      groupName: general
    - context: color
      description: Specify the background color for card. Any valid <a class="link external" href="https://www.w3schools.com/css/css_colors.asp" target="_blank">HTML color format (RGB/RGBA/HEX/HSL)</a> or <a class="link external" href="https://framework7.io/docs/css-variables.html" target="_blank">CSS theme</a> color. e.g. rgb(255,255,255), --f7-color-white. <b>Default = --f7-color-white</b>
      label: Background color
      required: false
      type: TEXT
      groupName: general
    - description: Specify the foreground color for text and icons. Any valid <a class="link external" href="https://www.w3schools.com/css/css_colors.asp" target="_blank">HTML color format (RGB/RGBA/HEX/HSL)</a> or <a class="link external" href="https://framework7.io/docs/css-variables.html" target="_blank">CSS theme</a> color. e.g. rgb(255,255,255), --f7-color-black. <b>Default = --f7-color-black</b>
      label: Foreground color (normal)
      required: false
      type: TEXT
      groupName: general
    - description: Specify the foreground color for highlighted text / icons (when warning condition is true). Any valid <a class="link external" href="https://www.w3schools.com/css/css_colors.asp" target="_blank">HTML color format (RGB/RGBA/HEX/HSL)</a> or <a class="link external" href="https://framework7.io/docs/css-variables.html" target="_blank">CSS theme</a> color. e.g. rgb(255,255,255), --f7-color-red. <b>Default = --f7-theme-color</b>
      label: Foreground color (warning)
      required: false
      type: TEXT
      groupName: general
  parameterGroups:
    - name: general
      label: Display options
    - name: items
      label: Items
    - name: warn
      label: Warning settings
timestamp: Jan 17, 2021, 2:45:45 AM
component: f7-card
  title: =props.title
  class:
    - padding
  style:
    background-image: ='url(' + props.backgroundUrl + ')'
    backdrop-filter: ='blur(' + props.backgroundBlur + 'px)'
    background-size: contain
    background-repeat: no-repeat
    background-position: 100% 100%
    background-color: "=(props.backgroundColor === undefined ? 'var(--f7-color-white)' : (props.backgroundColor.substring(0,2) === '--' ? 'var(' + props.backgroundColor + ')' : props.backgroundColor))"
    border-radius: 20px
    overflow: hidden
    -ms-user-select: none
    -moz-user-select: none
    -webkit-user-select: none
    user-select: none
    --normal-txt-color: "=(props.foregroundColor === undefined ? 'var(--f7-color-black)' : (props.foregroundColor.substring(0,2) === '--' ? 'var(' + props.foregroundColor + ')' : props.foregroundColor))"
    --warn-txt-color: "=(props.foregroundColorWarn === undefined ? 'var(--f7-theme-color)' : (props.foregroundColorWarn.substring(0,2) === '--' ? 'var(' + props.foregroundColorWarn + ')' : props.foregroundColorWarn))"
slots:
  default:
    - component: f7-block
        class:
          - no-padding
          - no-margin
        style:
          width: 100%
          height: 100%
          position: absolute
          top: 0
          left: 0
          border-radius: 20px
    - component: f7-swiper
        navigation: true
        class:
          - padding-top
        params:
          initalSlide: 0
          runCallbacksOnInit: true
          grabCursor: true
          observer: true
          observeSlideChildren: true
          updateOnWindowResize: true
          spaceBetween: 5
          mousewheel: true
          keyboard: true
          watchOverflow: true
          breakpoints:
            "0":
              slidesPerView: 1
            "240":
              slidesPerView: 2
            "320":
              slidesPerView: 3
            "480":
              slidesPerView: 4
            "640":
              slidesPerView: 5
        style:
          --swiper-navigation-size: 30px
          --swiper-navigation-color: var(--normal-txt-color)
      slots:
        default:
          - component: f7-swiper-slide
              expandable: true
              visible: =!(props.item1 === undefined)
              style:
                border-radius: 5px
            slots:
              default:
                - component: oh-button
                    action: analyzer
                    actionAnalyzerItems: =[props.item1]
                    class:
                      - justify-content-center
                      - align-items-center
                      - text-align-center
                    style:
                      height: 100%
                      --f7-button-hover-bg-color: var(--f7-color-white-shade)
                      --f7-button-pressed-bg-color: var(--f7-color-white-shade)
                  slots:
                    default:
                      - component: f7-icon
                          f7: radiowaves_right
                          style:
                            padding-right: 5px
                            color: '=(items[props.item1].state === props.warn1) ? "var(--warn-txt-color)" : "var(--normal-txt-color)"'
                      - component: Label
                          text: =items[props.item1].state
                          style:
                            font-size: 18px
                            font-weight: 400
              expandable: true
              visible: =!(props.item2 === undefined)
              style:
                border-radius: 5px
            slots:
              default:
                    action: analyzer
                    actionAnalyzerItems: =[props.item2]
                    class:
                      - text-align-center
                    style:
                      height: 100%
                  slots:
                    default:
                          f7: thermometer
                          style:
                            padding-right: 5px
                            color: '=(items[props.item2].state < props.warn2 ? "var(--warn-txt-color)" : "var(--normal-txt-color)")'
                      - component: Label
                          text: =items[(props.item2)].state
                          style:
                            font-size: 18px
                            font-weight: 400
              expandable: true
              visible: =!(props.item3 === undefined)
              style:
                border-radius: 5px
            slots:
              default:
                    action: analyzer
                    actionAnalyzerItems: =[props.item3]
                    class:
                      - text-align-center
                    style:
                      height: 100%
                  slots:
                    default:
                          f7: sun_max_fill
                          style:
                            padding-right: 5px
                            color: '=(Number(items[props.item3].state) < Number(props.warn3) ? "var(--warn-txt-color)" : "var(--normal-txt-color)")'
                      - component: Label
                          text: =items[(props.item3)].state + " Lux"
                          style:
                            font-size: 18px
                            font-weight: 400
              expandable: true
              visible: =!(props.item4 === undefined)
              style:
                border-radius: 5px
            slots:
              default:
                    action: analyzer
                    actionAnalyzerItems: =[props.item4]
                    class:
                      - text-align-center
                    style:
                      height: 100%
                  slots:
                    default:
                          f7: graph_square_fill
                          style:
                            padding-right: 5px
                            color: '=(items[props.item4].state === props.warn4) ? "var(--warn-txt-color)" : "var(--normal-txt-color)"'
                      - component: Label
                          text: =items[(props.item4)].state
                          style:
                            font-size: 18px
                            font-weight: 400
              expandable: true
              visible: =!(props.item5 === undefined)
              style:
                border-radius: 5px
            slots:
              default:
                    action: analyzer
                    actionAnalyzerItems: =[props.item5]
                    class:
                      - text-align-center
                    style:
                      height: 100%
                  slots:
                    default:
                          material: battery_charging_full
                          style:
                            padding-right: 5px
                            color: '=(Number(items[props.item5].state) < Number(props.warn5) ? "var(--warn-txt-color)" : "var(--normal-txt-color)")'
                      - component: Label
                          text: =items[(props.item5)].state + " %"
                          style:
                            font-size: 18px
                            font-weight: 400
Let me know if there are any ways in which this code could be improved. Always happy to learn. I’d also like to thank @ysc for the great work on the new UI.
Andy
Version 2, now supports any multi-sensor device with up to 7 different items/outputs. If the item is not populated in the widget properties, it is hidden from view. As standard:
  1. Motion sensor
  2. Door contact
  3. Temperature
  4. Light Intensity / UV
  5. Humidity
  6. Tamper
  7. Battery
Duplicate code has been removed and replaced with an oh-repeater:
          - component: oh-repeater
              sourceType: unset
              for: i
              in:
                - - item1
                  - warn1
                  - f7
                  - radiowaves_right
                - - item2
                  - warn2
                  - material
                  - sensor_door
                - - item3
                  - warn3
                  - f7
                  - thermometer
                - - item4
                  - warn4
                  - f7
                  - sun_max_fill
                  - Lux
                - - item5
                  - warn5
                  - f7
                  - drop_fill
                - - item6
                  - warn6
                  - f7
                  - graph_square_fill
                - - item7
                  - warn7
                  - material
                  - battery_charging_full
Each item in the “array” represents the variables for each button/slide:
                - - item1
                  - warn1
                  - f7
                  - radiowaves_right
  1. item1 is the property name that contains the item
  2. warn1 is the warning value property for the item
  3. f7 is the icon library required (possible values f7 or material)
  4. radiowaves_right is the icon name from either f7 or material icon list (openHAB icons not supported)
  5. == operator used for warning highlight/colour to be applied e.g. garage temperature in the image above. Valid values are == highlight when item equals warning value, < item less than warning value, > item greater than warning value.
Icons can be customised by changing sections 3/4. Warning highlight operator can be changed by amending 5 (you may also want to amend the associated warning property description to avoid confusion).
Syntax for referencing items in the unset for/loop took me ages to work out. Hopefully this may help someone else save some time:
'=items[props[loop.i[0]]].state'
Also improved the layout so that the navigation arrows don’t overlap with the slider buttons.
Changed the UID to reflect the more generic nature of the widget.
Here is the code:
uid: multisensor_card
tags: []
props:
  parameters:
    - context: item
      required: false
      type: TEXT
      groupName: items
    - context: item
      description: Name of the item containing door contact data. If undefined will not display the associated icon/text.
      label: Item Name (Door Contact)
      required: false
      type: TEXT
      groupName: items
    - context: item
      required: false
      type: TEXT
      groupName: items
    - context: item
      required: false
      type: TEXT
      groupName: items
    - context: item
      description: Name of the item containing humidity data. If undefined will not display the associated icon/text.
      label: Item name (Humidity)
      required: false
      type: TEXT
      groupName: items
    - context: item
      required: false
      type: TEXT
      groupName: items
    - context: item
      required: false
      type: TEXT
      groupName: items
      required: false
      type: TEXT
      groupName: warn
    - description: Highlight the door contact icon/text when the value equals the specified warning value e.g. ON. When undefined, no highlighting is displayed.
      label: Warning (Door contact)
      required: false
      type: TEXT
      groupName: warn
      required: false
      type: TEXT
      groupName: warn
      required: false
      type: INTEGER
      groupName: warn
    - description: Highlight the humidity sensor icon/text when the value is GREATER that the specified warning value e.g. 5. When undefined, no highlighting is displayed.
      label: Warning (Humidity sensor)
      required: false
      type: INTEGER
      groupName: warn
      required: false
      type: TEXT
      groupName: warn
      required: false
      type: INTEGER
      groupName: warn
      label: Card Title
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
    - context: color
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
  parameterGroups:
    - name: general
    - name: items
      label: Items
    - name: warn
timestamp: Jan 23, 2021, 9:33:04 PM
component: f7-card
  title: =props.title
  class:
    - padding
  style:
    border-radius: 5px
    overflow: hidden
    user-select: none
slots:
  default:
        navigation: true
        class:
          - padding-top
        params:
          initalSlide: 0
          grabCursor: true
          observer: true
          mousewheel: true
          keyboard: true
          watchOverflow: true
          slidesOffsetBefore: 30
          slidesOffsetAfter: 30
          breakpoints:
            "0":
              slidesPerView: 1
              spaceBetween: 0
            "240":
              slidesPerView: 2
              spaceBetween: 0
            "320":
              slidesPerView: 3
              spaceBetween: 0
            "480":
              slidesPerView: 4
              spaceBetween: 5
            "640":
              slidesPerView: auto
              spaceBetween: 5
        style:
      slots:
        default:
              sourceType: unset
              for: i
              in:
                - - item1
                  - warn1
                  - f7
                  - radiowaves_right
                - - item2
                  - warn2
                  - material
                  - sensor_door
                - - item3
                  - warn3
                  - f7
                  - thermometer
                - - item4
                  - warn4
                  - f7
                  - sun_max_fill
                  - Lux
                - - item5
                  - warn5
                  - f7
                  - drop_fill
                - - item6
                  - warn6
                  - f7
                  - graph_square_fill
                - - item7
                  - warn7
                  - material
              fragment: true
            slots:
              default:
                    expandable: true
                    visible: =!(props[loop.i[0]] === undefined)
                    style:
                      border-radius: 5px
                      width: 100px
                  slots:
                    default:
                          action: analyzer
                          actionAnalyzerItems: =[props[loop.i[0]]]
                          class:
                            - align-items-start
                            - text-align-center
                          style:
                            height: 100%
                        slots:
                          default:
                                f7: '=(loop.i[2]==="f7" ? loop.i[3] : "")'
                                material: '=(loop.i[2]==="material" ? loop.i[3] : "")'
                                style:
                                  padding-right: 5px
                                  color: '=(loop.i[4] == "==" ? (items[props[loop.i[0]]].state == props[loop.i[1]] ? "var(--warn-txt-color)" : "var(--normal-txt-color)") : (loop.i[4] == "<" ? (items[props[loop.i[0]]].state < props[loop.i[1]] ? "var(--warn-txt-color)" : "var(--normal-txt-color)") : "var(--normal-txt-color)"))'
                            - component: Label
                                text: '=items[props[loop.i[0]]].state + (loop.i[5] === undefined ? "" : " " + loop.i[5])'
                                style:
                                  font-size: 18px
                                  font-weight: 400
Let me know if there are any ways this can be improved. Andy
Very nice,
I will have to tweak my rip off version :blush:
I think one thing that might be worth a try is to make a version that assumes you have added equipment from the thing into the model including all of the points you want using default names. It would only be necessary then to set the equipment as all items would have names based on the equipment.
I think the challenge would be the zwave database would need to have consistent names for the equivalent endpoints for all supported devices so that it did not become very involved.
Based on your original (not latest) but only working for fibaro motion:
uid: fibaro_motion_equipment_card
tags: []
props:
  parameters:
    - context: item
      description: Name of the equipment containing motion sensor items. If undefined will not display the associated icon/text.
      label: Item Name (Motion sensor equipment)
      required: false
      type: TEXT
      groupName: items
      required: false
      type: TEXT
      groupName: warn
      required: false
      type: TEXT
      groupName: warn
      required: false
      type: TEXT
      groupName: warn
      required: false
      type: TEXT
      groupName: warn
      required: false
      type: TEXT
      groupName: warn
      label: Card Title
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
    - context: color
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
  parameterGroups:
    - name: general
    - name: items
      label: Items
    - name: warn
timestamp: Jan 24, 2021, 1:39:40 PM
component: f7-card
  title: =props.title
  class:
    - padding
  style:
    border-radius: 20px
    overflow: hidden
    user-select: none
slots:
  default:
        class:
          - no-padding
          - no-margin
        style:
          width: 100%
          height: 100%
          position: absolute
          top: 0
          left: 0
          border-radius: 20px
        navigation: true
        class:
          - padding-top
        params:
          initalSlide: 0
          grabCursor: true
          observer: true
          spaceBetween: 5
          mousewheel: true
          keyboard: true
          watchOverflow: true
          breakpoints:
            "0":
              slidesPerView: 1
            "240":
              slidesPerView: 2
            "320":
              slidesPerView: 3
            "480":
              slidesPerView: 4
            "640":
              slidesPerView: 5
        style:
      slots:
        default:
              expandable: true
              visible: "=(items[((!props.item1) ? '' : props.item1) + '_MotionAlarm'].state != '-')"
              style:
                border-radius: 5px
            slots:
              default:
                    action: analyzer
                    actionAnalyzerItems: "=[((!props.item1) ? '' : props.item1) + '_MotionAlarm']"
                    class:
                      - text-align-center
                    style:
                      height: 100%
                  slots:
                    default:
                          style:
                            padding-right: 5px
                            color: "=(items[((!props.item1) ? '' : props.item1) + '_MotionAlarm'].state === props.warn1) ? 'var(--warn-txt-color)' : 'var(--normal-txt-color)'"
                      - component: Label
                          text: "=items[((!props.item1) ? '' : props.item1) + '_MotionAlarm'].state"
                          style:
                            font-size: 18px
                            font-weight: 400
              expandable: true
              visible: "=(items[((!props.item1) ? '' : props.item1) + '_Sensortemperature'].state != '-')"
              style:
                border-radius: 5px
            slots:
              default:
                    action: analyzer
                    actionAnalyzerItems: "=[((!props.item1) ? '' : props.item1) + '_Sensortemperature']"
                    class:
                      - text-align-center
                    style:
                      height: 100%
                  slots:
                    default:
                          f7: thermometer
                          style:
                            padding-right: 5px
                            color: "=(items[((!props.item1) ? '' : props.item1) + '_Sensortemperature'].state < props.warn2) ? 'var(--warn-txt-color)' : 'var(--normal-txt-color)'"
                      - component: Label
                          text: "=items[((!props.item1) ? '' : props.item1) + '_Sensortemperature'].state"
                          style:
                            font-size: 18px
                            font-weight: 400
              expandable: true
              visible: "=(items[((!props.item1) ? '' : props.item1) + '_Sensorluminance'].state != '-')"
              style:
                border-radius: 5px
            slots:
              default:
                    action: analyzer
                    actionAnalyzerItems: "=[((!props.item1) ? '' : props.item1) + '_Sensorluminance']"
                    class:
                      - text-align-center
                    style:
                      height: 100%
                  slots:
                    default:
                          f7: sun_max_fill
                          style:
                            padding-right: 5px
                            color: "=(items[((!props.item1) ? '' : props.item1) + '_Sensorluminance'].state < props.warn3) ? 'var(--warn-txt-color)' : 'var(--normal-txt-color)'"
                      - component: Label
                          text: "=items[((!props.item1) ? '' : props.item1) + '_Sensorluminance'].state +' LUX'"
                          style:
                            font-size: 18px
                            font-weight: 400
              expandable: true
              visible: "=(items[((!props.item1) ? '' : props.item1) + '_Sensorseismicintensity'].state != '-')"
              style:
                border-radius: 5px
            slots:
              default:
                    action: analyzer
                    actionAnalyzerItems: "=[((!props.item1) ? '' : props.item1) + '_Sensorseismicintensity']"
                    class:
                      - text-align-center
                    style:
                      height: 100%
                  slots:
                    default:
                          style:
                            padding-right: 5px
                            color: "=(items[((!props.item1) ? '' : props.item1) + '_Sensorseismicintensity'].state > props.warn4) ? 'var(--warn-txt-color)' : 'var(--normal-txt-color)'"
                      - component: Label
                          text: "=items[((!props.item1) ? '' : props.item1) + '_Sensorseismicintensity'].state"
                          style:
                            font-size: 18px
                            font-weight: 400
              expandable: true
              visible: "=(items[((!props.item1) ? '' : props.item1) + '_BatteryLevel'].state != '-')"
              style:
                border-radius: 5px
            slots:
              default:
                    action: analyzer
                    actionAnalyzerItems: "=[((!props.item1) ? '' : props.item1) + '_BatteryLevel']"
                    class:
                      - text-align-center
                    style:
                      height: 100%
                  slots:
                    default:
                          style:
                            padding-right: 5px
                            color: "=(Number(items[((!props.item1) ? '' : props.item1) + '_BatteryLevel'].state) < Number(props.warn5) ? 'var(--warn-txt-color)' : 'var(--normal-txt-color)')"
                      - component: Label
                          text: "=items[((!props.item1) ? '' : props.item1) + '_BatteryLevel'].state + ' %'"
                          style:
                            font-size: 18px
                            font-weight: 400
Hi, I did consider what you described, but concluded that ‘consistent names’ could be the achilles heel of such an approach. As is, it supports any multi-function devices or even a way to aggregate outputs from separate devices into a single UI panel.
Ok, there are a few more lines of code in the properties section and it takes a few more minutes to set up, but as this is usually a one off process, I thought the compromise made sense for the flexibility offered.
Glad someone has found this useful :grinning: !
Andy
This is a brilliant widget and has helped me understand some of the dark arts such as repeaters. I am trying to include this in a room based “card” and I cant for the life of me work out how to remove the outline or shadow - any idea?
Take a look at this this post
Although this talks about adding styles, the general tips on using F12/inspect should help. Add box-shadow: none to the style: section of the f7-card section:
component: f7-card
  title: =props.title
  class:
    - padding
  style:
    box-shadow: none
That should take away the shadow. I don’t think there is any border (looks transparent from what I can see). But you can use the inspect trick to look for the style.
If it still looks like there is a border, check the background colours. Not all things that look white are pure white :stuck_out_tongue_winking_eye: You can override the default background-color (–f7-color-white) in the properties of the widget.
