OH3 - Widget to adjust the setpoint of my KNX Heating Actuators by 1bit element
Here my simple Solution of a small Widget.
OH3 - Widget to adjust the setpoint of my KNX Heating Actuators by an 1bit element. I use the heating actor MDT AKH-0800.
It takes me several hours to program this, because the documentation of the syntax is very poor.
(I was not able to find one, so I started with try and error.)
-> Maybe my code helps someone.
-> Or maybe someone has ideas to make is more beautiful.
(Change the color, make the columns better…)
For OH3 beginners:
Can create your own widgets here
This is the code of my simple widget:
uid: widget_adjust_setpoint_2
tags:
  - temperature
props:
  parameters:
    - description: A text prop
      label: Raum der Heizung
      required: false
      type: TEXT
    - context: item
      description: An item to control
      label: Sollwertverschiebungs item
      required: true
      type: TEXT
    - context: item
      label: Sollwert item
      required: true
      type: TEXT
    - context: item
      label: Istwert item
      required: true
      type: TEXT
    - context: item
      label: Stellwert des Ventils item
      required: true
      type: TEXT
  parameterGroups: []
timestamp: Feb 8, 2021, 12:01:18 AM
component: f7-row
  title: Test
slots:
  default:
    - component: Label
        text: =props.prop1
        style:
          margin-left: 20px
    - component: Label
        text: =(items[props.Istwert].displayState )
        style:
          margin-left: 20px
    - component: Label
        text: =(items[props.Stellwert].displayState )
        style:
          margin-left: 20px
    - component: oh-button
        action: command
        actionItem: =(props.Sollwertverschiebung)
        actionCommand: OFF
        actionModal: widget:YOURWIDGET
        icon-f7: minus_circle
        iconSize: 20
        iconColor: white
        raised: true
        large: true
        fill: true
        style:
          colour: blue
    - component: Label
        text: =(items[props.Sollwert].displayState )
        action: command
        actionCommand: ON
        icon-f7: plus_circle
        iconSize: 20
        iconColor: white
        raised: true
        large: true
        fill: true
Thanks for posting. We’ve been putting all the example widgets in the Add-ons UIs category so I move this post there.
Hi Michael,
I am using the same hardware from MDT. You can also use the beautiful widget from Nico. There are minor modification needed to run it with 1bit element, but you can use the code, that I already posted. If possible could you try whether you have the same issue with rounding?
https://community.openhab.org/t/oh3-heating-widget-based-on-css/115107/58?u=snowy
