If you use the same user/pw combination for both, it’ll work because the basic auth header is the same
This situation has been foreseen - and this has nothing to do with the authorization flow - the problem as you correctly identified is that NGINX and openHAB share the HTTP Authorization header and that leads to conflicts.
There’s a way to make the openHAB UI use a different header (X-OPENHAB-TOKEN
) in those cases, which is to make NGINX set a cookie accessible to JavaScript that will tell it to use a different header to transmit its own authorization credentials, the cookie’s name is X-OPENHAB-AUTH-HEADER
, you can set to any value you want as long as it is present. I know that this needs proper documentation but we’ll get there.
So anyway in NGINX putting something like this in your ‘location’ block should work:
add_header Set-Cookie X-OPENHAB-AUTH-HEADER=true;
See also https://github.com/openhab/openhab-cloud/pull/311 for openHAB Cloud.
Thanks @ysc, I got it working but I’m seeing multiple X-OPENHAB-AUTH-HEADER in the request header:
cookie: X-OPENHAB-AUTH-HEADER=1; X-OPENHAB-AUTH-HEADER=1
Do you know what could be causing this?
Will an NGINX with this header continue to work for OH2.X ?
Would it hence make sense to add that to the default NGINX configuration in openHABian ?
I don’t see any reason it won’t work. Yes it would make sense to add to openHABian.
OH3 now supports basic authentication, you’ll need to add the following to make it work:
add_header Set-Cookie X-OPENHAB-AUTH-HEADER=1;
proxy_set_header Authorization "";
If you don’t add the second line, you need to change the api security settings to allow basic authentication.
I was just coming here to add this, thanks!
Note: from a security perspective, that second line is rather important to include when you’re doing authorization at the reverse proxy level, it ensures the header containing the credentials meant to be exclusively for the proxy, are filtered out and not transmitted (likely in clear text) in the internal network.
Is there a link to the authentication model for OH3 and X-OPENHAB-AUTH-HEADER? A quick search here doesn’t match anything. I’m confused about the authentication support in OH3. I use a webbrowser that doesn’t support Basic Authentication and it would great if OH3 kept a cookie or supported Oauth.
If you use Traefik as reverse proxy, these lines do the job for basic auth. Append them to the OH service under “labels” in your docker-compose file.
- traefik.http.routers.openhab.middlewares=auth,oh
- traefik.http.middlewares.auth.basicauth.users=[generated by htpasswd]
- traefik.http.middlewares.auth.basicauth.removeHeader=true
- traefik.http.middlewares.oh.headers.customresponseheaders.Set-Cookie=X-OPENHAB-AUTH-HEADER=1
See the current template at https://github.com/openhab/openhabian/edit/master/includes/nginx.conf
Should I just add another add_header (i.e. line 24) or does it have to be inside the ‘location’ block as @ysc said ? Would I even need another such block ?
I’m trying to make it work, but even after adding this lines to nginx config file I still get “502 Bad Gateway” response.
Any ideas?
Thanks @ranielsen
would someone happen to know the equivalent for apache?
edit: a bit of digging late, i found a working config!
Header set Set-Cookie "X-OPENHAB-AUTH-HEADER=1"
ProxyPreserveHost On
ProxyPass / http://127.0.0.1:8080/
ProxyPassReverse http://127.0.0.1:8080/ /
Header add Authorization ""
RequestHeader set Authorization ""
This is my nginx config:
# openHABian NGINX Confiuration #
## Reverse Proxy to openHAB
server {
listen 1234;
server_name xxxxxxxxx;
location / {
proxy_pass http://localhost:8080;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
auth_basic "Username and Password Required";
auth_basic_user_file /etc/nginx/.htpasswd;
And OPENHAB 3 settings:
So if I have proxy_set_header Authorization "";
added to nginx config I can turn off “Allow Basic Authentication” in OH settings?
When now OH3 uses API Tokens does the lines need to be still in nginx conf?
What is the best way now to secure connections to OPENHAB 3.0?
did you or anyone figure out?
as far as I checked:
OH2 with nginx with Basic Auth - when I open Paper UI or Basic UI I needed to enter login and password same as in /etc/nginx/.htpasswd
on same nginx conf but on OH3 - when I open Openhab Main UI or Basic UI I needed to enter login and password set for administrator from Main UI
now I added SSL to nginx and on OH3 - when I open Main UI or Basic UI I enter login and pass from .htpasswd and also in Main UI addidtional login and pass for administrator.
here is my new nginx config:
server {
listen 80;
server_name xxxxxxxx;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl;
ssl_certificate /etc/ssl/openhab.crt;
ssl_certificate_key /etc/ssl/openhab.key;
location / {
proxy_set_header Upgrade $http_upgrade;
satisfy any;
allow 192.168.0.0/24;
allow 127.0.0.1;
deny all;
location /grafana/ {
proxy_pass http://localhost:3000/;
proxy_set_header X-Forwarded-Proto "https";
auth_basic "Unauthorised access prohibited";
location /frontail/ {
proxy_pass http://localhost:9001;
proxy_set_header Connection "upgrade";
You would need to create a user other than admin inside OH3, preferrably same name what you use in your oh client app and nginx conf.
Dunno how I think I saw some post here about doing that in Karaf console but I don’t find it any more.
(ping @hmerk I might be mistaken but wasn it you to write that?)
Sorry but I dont understand?
I only wrote that Now there is two levels of security. First is login and pass from nginx and then login and pass for administrator in Main UI.
Of course there is if you do not remove it from nginx.
Since you probably want to access without password, you need to create an oh user (and use that on the client side) inside oh3 and disable auth in nginx.
do you find the post?
EDIT: see Apache Karaf 2.4.5-SNAPSHOT Guides
