By default, the serial connection on the openHAB system is done with nrjavaserial.
Unfortunately there are some issues with this provider, so some (unstable) COM-connections can lock up after a while. See here:
In my case I had big problems with the connection to my smart meter trough an optical probe. As “workaround” I had to restart the whole openHAB instance after some hours. This was very frustrating.
Now there is a “real workaround”, which I found here in the forum more or less by accident.
So I want to share this here. I am very happy with it. On my system it is working since weeks without any issues. It should work with all bindings that need a serial connection.
The way it is done is very simple. See following steps:
Download .jar file:
Z-Wave USB stick not working after OH 3.1 update - #14 by splatch -
Put the file into your addons folder. See here:
Installation of Add-ons | openHAB -
Login to openHAB Console. See here:
The Console | openHAB -
Check if the PureJavaComm provicer is active:
openhab> bundle:list | grep ConnectorIO
Result should be like this:
351 x Active x 80 x 3.0.0.202107051005 x ConnectorIO PureJavaComm serial port provider
Reboot your system.
Now you should be able to change the port identifier in the thing configuration:
purejavacomm uses different port identifiers (ttyUSB0) from rxtx (/dev/ttyUSB0). So in my case the prefix “/dev/” is no more needed in the configuration.
Your serial device should already get online and work like expected.
If you see exceptions in log or it is still unstable just uninstall rxtx bundles (la -l|grep rxtx, then remove bundle without rfc in the name).
bundle:uninstall XXX
Where XXX is the ID of your bundle.
See also here:
So at the end it should look like this.
openhab> la -l|grep rxtx
339 x Installed x 80 x 3.2.0.M3 x mvn:org.openhab.core.bundles/org.openhab.core.io.transport.serial.rxtx.rfc2217/3.2.0.M3
If you use rfc ports at the same time then they will fail without main part of rxtx.
This is it. Any comments on this are very welcome.
Please beware, I am not a Linux or openHAB specialist.
So everything I said before can be wrong. I am just explaining a way how to work with a different serial provider. In my case I am a lot more happier with the alternative.
All thanks and credits to @splatch who developed this. Thank you very much.
