I have several z-wave light switches/dimmers and the system is controlling them fine.
However if someone manually changes a dimmer or switches off a light using the device, that change is never reflected back to the GUI. Communication seems to be only one-way.
I thought the Profile parameter might have some effect on this but none of the available choices seemed to make any difference.
Usually I have been setting them up as points in the Model, either dimmers or switches
It’s up to each zwave device who it reports to, if anybody. Some device configuration option should point to your zwave controller. I know the word “lifeline” but leave it to zwave knowledgable folk to fill in here.
Meantime, remove any Item link profiles, definitely not wanted here.
That is correct. Have a look at your Z Wave Device Thing not reporting the Status and check the Assocation Group 1, Lifeline. You should set ‘Controller’ for this group.
Here is an example of a dimmer in my network, which works fine from openhab and manual.
The binding never updates the GUI. The binding updates Items, the GUI displays Items. Divide and conquer.
You might look in your events.log to see if your Items are being updated as expected. Then you will know whether to look for some display issue, or something on the channel/Thing/binding side.
Good comparison.
If a channel is not linked to anything (an Item), I don’t think it gets an update.
You might look to see if you have any Items linked to something like zwave:... :node14:switch_dimmer
@brianlay Thanks for referencing my post about this same issue. I’m still having the same problem with my Zooz switches and dimmers. I talked to Zooz support as well and they recommended I post on the openHAB community forum for help.
I hope we can get some help from the z-wave experts on this forum to get this resolved.
The issue was (hopefully) that the device is sending basic reports, and the database was not configured to use these reports as if they were dimmer reports. I have simply changed this setting.
