[OH3] Z2M Home Assistance auto discovery creates channel as a trigger
Hello.
Setup:
OH3 3.2
Z2M 1.21.0
Aqara curtain motor Xiaomi ZNCLDJ11LM control via MQTT | zigbee2mqtt.io
The thing is discovered as:
UID: mqtt:homeassistant_zigbee2mqtt_5F0x00158d00027275d9:main:zigbee2mqtt_5F0x00158d00027275d9
label: VadimBlind
thingTypeUID: mqtt:homeassistant_zigbee2mqtt_5F0x00158d00027275d9
configuration:
  topics:
    - sensor/0x00158d00027275d9/update_state
    - cover/0x00158d00027275d9/cover
    - sensor/0x00158d00027275d9/linkquality
    - binary_sensor/0x00158d00027275d9/update_available
  basetopic: homeassistant
bridgeUID: mqtt:systemBroker:main
    "availability": [
            "topic": "zigbee2mqtt/bridge/state"
    "command_topic": "zigbee2mqtt/VadimBlind/set",
    "device": {
        "identifiers": [
            "zigbee2mqtt_0x00158d00027275d9"
        "manufacturer": "Xiaomi",
        "model": "Aqara curtain motor (ZNCLDJ11LM)",
        "name": "VadimBlind",
        "sw_version": "Zigbee2MQTT 1.19.1"
    "json_attributes_topic": "zigbee2mqtt/VadimBlind",
    "position_template": "{{ value_json.position }}",
    "position_topic": "zigbee2mqtt/VadimBlind",
    "set_position_template": "{ \"position\": {{ position }} }",
    "set_position_topic": "zigbee2mqtt/VadimBlind/set",
    "unique_id": "0x00158d00027275d9_cover_zigbee2mqtt"
the channel cover is created as trigger.
but I cannot create an item for it, it says:
how can I link the item to this channel? as I want to open/close blind
Thanks!
did you find a way to do what you are asking …
I have a similar issue with lightbulb …
