I have had a Yale Conexis L1 with ZWave module 2 for a few years and previously controlled it using the Z-Way binding. I moved several months ago to ZWave to have a more integrated solution into Openhab. However I have been unable to get the Yale Lock to pair. It simply shows Unknown Device and remains like this even though I open/close the lock several times in order of the pairing to complete. I have also had the controller within a meter of the lock. I have now added an additional Yale Conexis L1 to a different door with new Zwave 2 module and I get exactly the same response. Two xml files have been created (one for each node) but minimal data is present. Running OH Ver 3.2 with Binding of the same version. I checked the database and the lock seems to be present.
<node>
<homeId>xxxxxxxxxxxx</homeId>
<nodeId>16</nodeId>
<version>4</version>
<manufacturer>0x7fffffff</manufacturer>
<deviceId>0x7fffffff</deviceId>
<deviceType>0x7fffffff</deviceType>
<listening>false</listening>
<frequentlyListening>true</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
<commandClass>COMMAND_CLASS_SECURITY</commandClass>
<commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map"/>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_ENTRY_CONTROL</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_SECURE_KEYPAD_DOOR_LOCK</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<COMMAND__CLASS__BASIC>
<version>0</version>
<versionSupported>0</versionSupported>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>1</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_SLEEPING_LISTENING</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__SECURITY>
</COMMAND__CLASS__SECURITY>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>1</int>
<int>3</int>
<int>7</int>
<int>14</int>
</nodeNeighbors>
<lastReceived>2022-01-15 15:31:42.252 UTC</lastReceived>
</node>
Can anyone provide any pointers please?
