OH4.0.0: How do I call an UI script from ECMAScript 2022+ rule
  • Platform information:
    • openHAB version: 4.0.0
I am migrating from OH3 to OH4. One of my ECMAScript 2022+ rules is calling a script in the UI script folder (not in configurations/scripts !). I used to call this script this way:
var FrameworkUtil = Java.type("org.osgi.framework.FrameworkUtil");
var _bundle = FrameworkUtil.getBundle(scriptExtension.class);
var bundle_context = _bundle.getBundleContext();
var classname = "org.openhab.core.automation.RuleManager";
var RuleManager_Ref = bundle_context.getServiceReference(classname);
var RuleManager = bundle_context.getService(RuleManager_Ref);
RuleManager.runNow("OtherScript");
but in OH4.0.0 this leads to the error
Script execution of rule with UID ‘RunScript’ failed: org.graalvm.polyglot.PolyglotException: ReferenceError: “scriptExtension” is not defined
I have also tried
actions.ScriptExecution.callScript("OtherScript");
but this leads to the following error:
Script execution of rule with UID ‘OtherScript’ failed: org.openhab.core.model.script.engine.ScriptExecutionException: Script ‘OtherScript’ cannot be found.
This fits to the documentations that states:
Calls a script which must be located in the configurations/scripts folder.
So my question is: How would I call a script in the UI scripts folder from my ECMAScript 2022+ rule?
Thanks for helping!
In the new JSScripting, this is covered in the helper library. All you need is:
rules.runRule('uid-of-rule')
Works fine, thank you very much.
I find it a bit misleading that rules.runRule() starts rules and scripts though.
This is a common comment. The term ‘scripts’ is used in several independent cases in OH. In this case it’s easiest to just remember that the UI managed scripts (and the new UI managed scenes) are just special rules. They show up on different pages in the UI to make it slightly easier to track and create these special versions of rules, but in the end, they are still just rules. For example, the UI “scripts” are just rules that don’t have a defined trigger. With no trigger, there is no event in OH that will cause the body of the script(rule) to run, but they can be called to run in any other way that a rule can be run.
It would be better if there was non-overlapping terminology for these various “script” instances, but no matter how often users get tripped up a little by it, no one has yet managed to propose an alternative that is better (several have tried).
Thank you for the explanation, I didn’t know that. I appreciate it when I can gain deeper insights :slight_smile:
The command below does work:
rules.runRule(‘uid-of-rule’)
but why doesn’t rule show up if I press ctrl-space to show the drop down options when writing a rule?
Lots of other options appear if I press ctrl-space.
Is there something else I need to install? I have JavaScript Scripting installed.
I am using openHab 4.0.4 and ECMAscript 262 Edition 11 and totally UI (no files)
Certain parts of the JSScripting add-on are part of the core functions of the add-on and other parts come from the helper library that is installed along with it. I don’t know how complete the integration between the helper library and the editor hints is.
When in doubt, you can always look up the helper library docs:
https://openhab.github.io/openhab-js/rules.html
Is it also possible to import a function (or all functions) from a UI script, so it could be used as a library?
And what about constants/variables defined there?
(I tried running a script with a function definition using rules.runRule(), but this did not make the function accessible afterwards…)
No. The UI scripts are not included in the rule you call them from, they are run separately with their own thread and context.
Same as above.
If you want to have a javascript library you must write it outside of OH and either install is as your own node module or at least keep the library files someplace that that OH has access to so that you can include the library manually in each script that needs it.
