[OH5] OpenHABian - System update issue
Hello all, hello mstormi
After a couple of days I was logon on the OpenHABian menue,
The console tell me that:
openhabian@openhabian:~ $ sudo openhabian-config
[sudo] password for openhabian:
2025-07-31_12:03:59_CEST [openHABian] Checking for root privileges... OK
2025-07-31_12:03:59_CEST [openHABian] Making sure router advertisements are available... OK
2025-07-31_12:03:59_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2025-07-31_12:04:00_CEST [openHABian] openHABian configuration tool version: [openHAB]{2025-07-23T07:52:37+02:00}(ff78de1)
2025-07-31_12:04:00_CEST [openHABian] Checking for changes in origin branch openHAB... Updates available... UPDATING
2025-07-31_12:04:04_CEST [openHABian] Updating myself... mv: cannot stat '/opt/openhabian/docs/NEWS.md': No such file or directory
OK - Commit history (oldest to newest):
905567a - Break on no `/opt/jdk` (#2024) (7 days ago) <Ethan Dye> E
 functions/java-jre.bash | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
a59ab3f - allow for trixie (#2026) (2 days ago) <Markus Storm> E
 functions/helpers.bash | 12 +++++++++---
 1 file changed, 9 insertions(+), 3 deletions(-)
d339d2d - Force new config, allow for trixie (#2030) (2 days ago) <Markus Storm> E
 functions/java-jre.bash | 6 +++---
 functions/openhab.bash  | 2 +-
 functions/system.bash   | 2 +-
 functions/wifi.bash     | 2 +-
 4 files changed, 6 insertions(+), 6 deletions(-)
f799d48 - Temurin21 32bit (#2031) (2 days ago) <Markus Storm> E
 functions/java-jre.bash | 34 ++++++++++++++++++++++++++++++----
 1 file changed, 30 insertions(+), 4 deletions(-)
868c89d - Fix build (#2032) (24 hours ago) <Markus Storm> E
 .github/workflows/installation-action.yml      | 14 +++++++-------
 build-image/offline-install-modifications.bash |  6 +++++-
 functions/java-jre.bash                        |  2 +-
 3 files changed, 13 insertions(+), 9 deletions(-)
10f5bf2 - default Java->Temurin21, default debuglevel on (#2033) (21 hours ago) <Markus Storm> E
 build-image/openhabian.conf | 4 ++--
 functions/system.bash       | 4 ++--
 openhabian-setup.sh         | 2 +-
 3 files changed, 5 insertions(+), 5 deletions(-)
4b441ac - OpenHAB4 branch to install OH4 (#2035) (17 hours ago) <Markus Storm> E
 README.md           |  4 ++--
 docs/openhabian.md  | 12 ++++++------
 openhabian-setup.sh |  3 +++
 3 files changed, 11 insertions(+), 8 deletions(-)
d4e2a5d - back to installing OH5 by default (#2036) (17 hours ago) <Markus Storm> E
 openhabian-setup.sh | 3 ---
 1 file changed, 3 deletions(-)
openHABian configuration tool successfully updated.
Visit the development repository for more details: https://github.com/openhab/openhabian
The tool will now restart to load the updates... OK
2025-07-31_12:04:05_CEST [openHABian] Checking for root privileges... OK
2025-07-31_12:04:06_CEST [openHABian] Making sure router advertisements are available... OK
2025-07-31_12:04:06_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2025-07-31_12:04:06_CEST [openHABian] openHABian configuration tool version: [openHAB]{2025-07-30T19:18:02+02:00}(d4e2a5d)
2025-07-31_12:04:06_CEST [openHABian] Checking for changes in origin branch openHAB... OK
2025-07-31_12:04:08_CEST [openHABian] Switching to branch openHAB... OK
2025-07-31_12:04:08_CEST [openHABian] Checking openHAB Signing Key expiry.
2025-07-31_12:04:08_CEST [openHABian] Checking expiry date of apt keys... OK
2025-07-31_12:04:14_CEST [openHABian] Updating Linux package information... OK
2025-07-31_12:04:14_CEST [openHABian] Updating repositories and upgrading installed packages...
E: Command line option --force-confnew is not understood in combination with the other options
FAILED
2025-07-31_12:04:17_CEST [openHABian] Updating Linux package information... OK
2025-07-31_12:04:17_CEST [openHABian] Updating repositories and upgrading installed packages...
FAILED
2025-07-31_12:04:26_CEST [openHABian] Checking for default openHABian username:password combination... FAILED
2025-07-31_12:04:26_CEST [openHABian] We hope you got what you came for! See you again soon ;)
your code goes here
After that I cannot more do an System-Update (menu point 02)…
From now on, I cannot make anymore an system update which I have done before many, many times, over many years.
          │ There was an error or interruption during the execution of:                  │
          │   "02 | Upgrade System"                                                      │
          │ Please try again. If the error persists, please read                         │
          │ /opt/openhabian/docs/openhabian-troubleshooting.md or                        │
          │ https://www.openhab.org/docs/installation/openhabian-troubleshooting.html    │
          │ how to proceed.                                                              │
          │                                    <Ok>                                      │
try again (update on openhabian-config start)
Thanks. It is working again…
