[OH5] TR-064 Implementation
openHAB 5.2.0
I just migrated my broadband from cable to fibre channel, now using a Fritz!Box 5590 FW 8.25.
While the most items were easy to transfer and may just used a quick reconfigure, I’m stuck with the data from the down- and upload-speeds.
2026-09-11 14:52:56.982 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item fboxWANDSBitRate' changed from NULL to 0.001024 Mbit/s
2026-09-11 14:52:56.995 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'fboxWANUSBitRate' changed from NULL to 5.12E-4 Mbit/s
Well, basically the values are reported as zero, although the Fritz!Box does show the correct download values.
As documented for the TR064 Add-on, accroding to the according WAN subdevice channels documentation I use the wanMaxDownstreamRate and wanMaxUpstreamRate channels.
Anyone experiencing the same issue and fixed it?
after moving off cable/dsl onto fibre those wanMaxDownstreamRate / wanMaxUpstreamRate channels often sit near zero for me. they come from TR-064 GetCommonLinkProperties and on a 5590 fibre path AVM just doesnt fill them the same way. try wanCurrentDownstreamRate / wanCurrentUpstreamRate instead (15s average traffic, not your contract speed). the provisioned fibre speed usually isnt exposed over TR-064 at all. the dsl* channels wont help once wanAccessType is fibre either.
Thanks! I already guessed something like this, and you just confirmed. :+1:
