Hello, I am creating a widget, that will control my lighting system. I want to have this widget dynamic, so it will load all lights in the predefined premises (eg. room, floor, house, etc.). So I’ve created a new AngularJS controller, that should load all lights in the predefined premises during page load. The issue I am facing is, that during every first load (or reload), OHService.getItem(ItemName) returns null, but when I visit the dashboard with this widget as a second page (firstly open another dashboard and then open the menu and switch to the desired dashboard), the command works as expected.
The whole widget is inside <div ng-controller="ngLightsCtrl" ng-init="initLights(config.place)">
and the corresponding JavaScript code:
function () {
'use strict';
angular
.module('app.widgets.lights', [])
.controller('ngLightsCtrl', ['$rootScope', '$scope', 'OHService',
function ($rootScope, $scope, OHService) {
function getLights (HausePart)
var itemsInGroup = $scope.itemsInGroup(HausePart.name);
for (var i = 0; i < itemsInGroup.length ; i++)
var item = itemsInGroup[i];
if (item.groupNames.includes('gLight')) {$scope['Lights'].push(item); }
else {getLights(item);}
$scope['initLights'] = function (HausePart)
$scope['Lights'] = [];
var item = OHService.getItem(HausePart); // this command returns NULL
getLights (item)
$scope['Modals'] = [];
Could you please tell me what is wrong? Why the first load of the page doesn’t work?
Gregorij
UPDATE:
I´ve discovered, that this is happening because the loading of the items ends after my script is executed. How should I wait for the items to be loaded (e.g. $rootScope.items not to be null)?
