hi,
I just upgraded from OH2 to OH3 and got almost everything up and running again. Only an old copy-pasted rule for parsing the output of “apcaccess -u” to give me information about my APC USV is not working anymore.
Logfile says:
2021-05-17 09:30:44.263 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'apc-1' failed: An error occurred during the script execution: Could not invoke constructor: org.openhab.core.library.types.DateTimeType.DateTimeType(java.time.ZonedDateTime) in apc
Already back in OH2 I got the “DateTime is deprecated” warning, but it was still working.
Here ist the rule:
import java.io.BufferedReader
import java.io.StringReader
import java.util.Calendar
import java.text.SimpleDateFormat
import java.text.ParseException
rule "APC: Parse raw output from command-line tool"
Item APC_Raw changed
var output = APC_Raw.state.toString
var String line
var String[] buffer
var String value
var bufReader = new BufferedReader(new StringReader(output))
var Calendar cal = Calendar.getInstance()
var formatStrings = newArrayList('yyyy-MM-dd HH:mm:ss Z', 'yyyy-MM-dd')
while((line = bufReader.readLine()) !== null) {
buffer = line.split(':', 2)
for (var i = 0; i < 2; i++) {
buffer.set(i, buffer.get(i).trim())
// check if there’s an item for this key (e.g. APC_STARTTIME)
var item = gAPC.members.findFirst[name.equals("APC_" + buffer.get(0))]
if (item !== null) {
value = buffer.get(1)
// DateTime item: try to parse date
if (item.type == 'DateTime') {
var succeeded = false
for (String formatString : formatStrings) {
try {
if (!succeeded) { // no `break` statement in openHAB :(
cal.setTime(new SimpleDateFormat(formatString).parse(value))
item.postUpdate(new DateTimeType(cal).toString)
succeeded = true
} catch (ParseException e) { }
// String or Number: just update the value
} else {
item.postUpdate(value)
// Calculate Watts
APC_LOAD.postUpdate(APC_LOADPCT.state as Number * 5)
Thanks Russ!
With OH2 it was working. It reads the UPS, all in one string, but I have some problems in reading the single values in the string. It gaves me an error with calendar.
Managed to correct the “Battery Date” but not the “Start Time”.
Here is the code, if it helps you
//var output = APC_Raw.state.toString
var output = APC_Raw.state.toString.replace('~','\n')
var String line
var String[] buffer
var String value
//var formatStrings = newArrayList('yyyy-MM-dd HH:mm:ss Z', 'yyyy-MM-dd')
var formatStrings = newArrayList('yyyy-MM-dd')
try {
val MyEpochFromJavaTime_VariantA = cal.toInstant.toEpochMilli
//item.postUpdate(new DateTimeType(cal).toString)
item.postUpdate(MyEpochFromJavaTime_VariantA)
succeeded = true
} else {
