Old v2 rule into gui code
Hi, I have a rule that I need to upgrade. It used to work in 2.x but no longer in 3.x
I would be happy with help to put it in a rules file or the Gui code section.
Can someone please help me out, I have tried all day with no joy.
Here is my old rule that doesnt like " receivedEvent.getEvent()"
rule “Mijia Wireless Switch”
Channel “mihome:sensor_switch:04cf8c9783a3:158d0002f80bdc:button” triggered
var actionName = receivedEvent.getEvent()
switch(actionName) {
case “SHORT_PRESSED”: {
if (SW3_01_1.state != ON)
SW3_01_1.sendCommand(ON)
else SW3_01_1.sendCommand(OFF)
    case "DOUBLE_PRESSED": {
        if (SW3_01_2.state != ON)
             SW3_01_2.sendCommand(ON)
         else  SW3_01_2.sendCommand(OFF)
        //currState = currState + 1
        //val func2 = brlight.get(currState % brlight.size)
        //func2.apply()
    case "LONG_PRESSED": {
        if (SW3_01_3.state != ON)
             SW3_01_3.sendCommand(ON)
         else  SW3_01_3.sendCommand(OFF)
    //case "LONG_RELEASED": {
    //    Bedroom_Light.sendCommand(100)
see here
it is now
receivedEvent
Seriously?
So just to be sure, it’s
instead of
The manual said get rid of getEvent but didn’t know thats what it meant.
Cheers
Yes. No need to assign receivedEvent to a variable as receivedEvent already is a variable
Thanks working Well.
        //func2.apply()
A couple of things.
First, please use code fences when pasting code or logs to the forum.
code goes here
To answer parts of your question not yet answered:
To make this a UI rule is pretty straight forward.
  1. Navigate to Settings → Rules → + to create a new rule
  2. Fill out the ID, name, and description
  3. Add a trigger → Thing Event → your mihome Channel
  4. Add an action → Script Action → Rules DSL
  5. copy the code between then and end into the script action
That’s it. For this rule it’s pretty simple.
You could look into reimplementing it as Blockly or one of the other languages but it’s not necessary.
Thanks Rich and Oliver, much appreciated.
I did get the old Rule to work by making 6 simple rules in the ui. 2 for each of the 3 triggers, your way seems much easier.
Cheers
