I have noticed that after many hours (but always less than a day) - the Omnilink driver will stop receiving and processing updates from the omni panel.
I am using the 1.9 snapshot driver.
I see log messages just stop after a while.
These are the last messages I see in the log:
2017-01-16 03:09:04.381 [DEBUG] [ng.omnilink.internal.OmniLinkBinding] - Received Status Notification ObjectStatus ( )
2017-01-16 03:09:04.381 [DEBUG] [ng.omnilink.internal.OmniLinkBinding] - updateDeviceStatus 385 class com.digitaldan.jomnilinkII.MessageTypes.statuses.UnitStatus
2017-01-16 03:09:04.382 [DEBUG] [binding.omnilink.internal.model.Unit] - Unit state 0
2017-01-16 03:09:04.382 [DEBUG] [binding.omnilink.internal.model.Unit] - updating percent type 0
That was over 4 hours ago. Many HLC lights have been turned on and off since then.
I can see a connection existing between the openhab server and the omni panel:
netstat -an | grep 10.0.0.80 tcp6 0 0 10.0.0.16:36884 10.0.0.80:4369 ESTABLISHED
I forced a thread dump. I don’t see anything abnormal at a quick glance. Here are the associated entries:
Thread 31829: (state = BLOCKED)
- java.lang.Thread.sleep(long) @bci=0 (Compiled frame; information may be imprecise)
- com.digitaldan.jomnilinkII.Connection$ConnectionWatchdog.run() @bci=78 (Interpreted frame)
Thread 31827: (state = IN_NATIVE)
- java.net.SocketInputStream.socketRead0(java.io.FileDescriptor, byte, int, int, int) @bci=0 (Compiled frame; information may be imprecise)
- java.net.SocketInputStream.socketRead(java.io.FileDescriptor, byte, int, int, int) @bci=8, line=116 (Compiled frame)
- java.net.SocketInputStream.read(byte, int, int, int) @bci=79, line=170 (Compiled frame)
- java.net.SocketInputStream.read(byte, int, int) @bci=11, line=141 (Compiled frame)
- java.net.SocketInputStream.read() @bci=23, line=223 (Compiled frame)
- java.io.DataInputStream.readUnsignedShort() @bci=4, line=337 (Compiled frame)
- com.digitaldan.jomnilinkII.Connection.readBytesEncrypted2() @bci=58 (Compiled frame)
- com.digitaldan.jomnilinkII.Connection.run() @bci=15 (Compiled frame)
Thread 31826: (state = BLOCKED)
- java.lang.Object.wait(long) @bci=0 (Compiled frame; information may be imprecise)
- org.openhab.binding.omnilink.internal.OmniLinkBinding$OmniConnectionThread.run() @bci=313, line=444 (Interpreted frame)
Anyone else run into this?
