Hi
I have an on/off switch controlling the power for a ventilation unit which I run when the humidity in the bathroom exceeds a threshold, and turn it off again when the humidity is low. This has worked like a charm for a while.
I just moved my OpenHAB VM to another hypervisor a couple days ago along with the zwave USB stick and everything seems to work, except that the plug seems unable to report it’s actual state.
Rule snippet:
if (Bathroom_humidity.state < 60 && Bathroom_upstairs_humidity.state < 60) {
//if (Metered_plug_ventilation_switch.state == ON ) {
sendCommand(Metered_plug_ventilation_switch, OFF)
I had to comment out the state check to get the rule to turn it off which works but now it sends the OFF over and over again.
The plug thing:
Switch Metered_plug_ventilation_switch { channel="zwave:device:controller:node4:switch_binary", autoupdate="false" }
Also, there is no zwave device map in habmin.
I believed the state of the plug should reflect reality with autoupdate=false but that is not the case. Any suggestions on what happened and how to fix it? Some sort of network problem?
Thanks,
Torkil
