I know this issue has been discussed many times but I guess I am too old to see what I am doing wrong.
I have a motion sensor it is normally closed, it opens when it senses movement.
I want to program a script to set the state as occupied when motion is detected and empty after 10 minutes of no motion detection.
This is my script, which is triggered every time there is a change in the state of the motion sensor
var Timer ktimer
if(Sensors_KitchenMotionSensor.state == CLOSED){
ktimer = createTimer(now.plusSeconds(600), [|
KitchenOccupancy.postUpdate("EMPTY")])
else
KitchenOccupancy.postUpdate("OCCUPIED")
if(ktimer != null){
ktimer.cancel
ktimer=null
The timer never gets cancelled, on the first movement (open) signal the status changes from empty to occupied and 10 minutes later it goes back to empty no matter how many times the sensor detects movement.
Thank you
