I am trying to set-up a couple of rules to control groups of lamps. The lamps are members of groups like
gMorninglights and gDusklights
As control for the rules I have implemented a TimeOfDay rule that based on time of day, sunrise, sunset etc. will tell if Item String TimeOfDay is either MORNING, DAY, AFTERNOON, EVENING or NIGHT. This is modelled after another topic I have found in the community and it seems to work fine. Now for the issue:
Assuming it is EVENING:
This rule:
rule "Morninglights on" //Lights on all the time when it is not NIGHT
Item Solna_TimeOfDay received command
if(Solna_TimeOfDay != "NIGHT") {
gMorninglights.members.forEach[ i |
i.sendCommand(ON)
Thread::sleep(250)
logInfo("Lights", "Setting gMorninglights to ON")
Works fine.
This rule:
rule âDusk lights onâ //Lights on in the EVENING
if(Solna_TimeOfDay == "EVENING") {
gDusklights.members.forEach[ i |
i.sendCommand(ON)
Thread::sleep(250)
logInfo("Lights", "Setting gDusklights to ON")
Never fires.
This is what log shows:
2017-12-07 17:40:54.439 [INFO ] [pse.smarthome.model.script.timeofday] - Current time of day is now EVENING
2017-12-07 17:40:54.447 [ome.event.ItemCommandEvent] - Item âSolna_TimeOfDayâ received command EVENING
2017-12-07 17:40:54.466 [ome.event.ItemCommandEvent] - Item âSolna_TV_Flowerâ received command ON
2017-12-07 17:40:54.717 [INFO ] [clipse.smarthome.model.script.Lights] - Setting gMorninglights to ON
There should have been a corresponding entry -Setting gDusklights to ON
I donât know if it helps, but you could have both if-expressions in one rule. There probably shouldnât be any conflicts between two rules sharing the same trigger, but might be worth a try.
OK! Tried that. Now all rules related to TimeOfDay are in the same rule.
Also tried to change the order of ifâs. No change. Only the !=NIGHT rule fires, not the ==EVENING
rule "Morninglights" //Combined all light rules in one
i.sendCommand(ON)
Thread::sleep(250)
else
i.sendCommand(ON)
Thread::sleep(250)
else
if(Solna_TimeOfDay == "NIGHT") {
gLights.members.forEach[ i |
i.sendCommand(OFF)
Thread::sleep(250)
logInfo("Lights", "Setting gLights to OFF")
will always be true as the item is an object and not a string and therefore will always NOT be equal to any string.
Would strongly suggest to read the docs: http://docs.openhab.org/configuration/items.html#state
you could try Solna_TimeOfDay.state in your comparisons instead of only the item name.
You are great Markus!
This seems to work. Now TODO read again the docs (for the XX-time).
I started on OH 1.8 some years ago and have now graduated to 2.1 but it is still an up-hill struggle.
Thanks to the community there always the chance of making progress.
Please keep in mind, that you are actually trying to compare a state to a string (even if the item is a string item). Luckily openHAB does the .toString autoamtically, but to use it correct:
if(MySwitchItem.state == ON) //MySwitchItem is of type switch, so compare to real state
if(MyContactItem.state == OPEN) //MyContactItem is of type contact, so compare to real state
if(MyStringItem.state.toString == "Text") //MyStringItem is of type string, so compare string with string
if((MyNumberItem.state as Number) == 15) //MyNumberItem is of type number, so cast state to number, then compare number with
if((MyDimmerItem.state as Number) == 45) //MyDimmerItem is of type dimmer, so cast state to Number, then compare number with number
Udo is right! The lights are operated through Tellstick and I do not want to swamp the Tellstick DUO. Not sure if the binding can queue up commands but this is just to be on the safe side.
