I know the README for the manual update script lists how to do it manually. I do not have the forum link handy right now.
I have updated manually the zwave binding by 2.5.5.202005041107 and confirm that it works with the HomeSeer motion detector HS-MS100+.
Here is my test rule:
rule "Test Motion detector on"
Item zwave_device_129fb235_node24_alarm_motion changed from OFF to ON
logInfo('test', "It detects!")
rule "Test Motion detector off"
Item zwave_device_129fb235_node24_alarm_motion changed from ON to OFF
logInfo('test', "It sleeps!")
rule "test sleep"
logInfo('Test Motion detector.rules', "Detects change!")
zwave_device_129fb235_node22_switch_dimmer.sendCommand(50)
And the log:
openhab> list -s | grep -i zwave
248 │ Active │ 80 │ 2.5.5.202005041107 │ org.openhab.binding.zwave
openhab> log:tail
21:27:13.187 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 2183 to 2184
21:27:13.201 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 2184 to 2185
21:27:15.657 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 2185 to 2186
21:27:15.668 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_device_129fb235_node24_alarm_motion changed from OFF to ON
21:27:15.668 [INFO ] [g.eclipse.smarthome.model.script.test] - It detects!
21:27:15.668 [INFO ] [del.script.Test Motion detector.rules] - Detects change!
Thanks for all. Learned a lot:)
Robin
