Platform information:
- Hardware: Raspberry Pi 4
- OS: openhabian
- openHAB version: 3.3
- Key bindings: KNX, MQTT
I have a lighting circuit on a KNX standard switching module bound into openhab via the KNX binding to a a banale swith Thing
, like so:
- id: BDL1
channelTypeUID: knx:switch
label: 💡⊡ Central Light 💻
configuration:
ga: 1/2/11+<1/2/111
(1/2/11 is the sending, and 1/2/111 in the acknowledging KNX Group Address).
I would like to control this light from the (KNX Wall switch - done!), and the openhab MainUI through an Item (easy ). In addition I would like to switch the Thing
ON
via a (zigbee2mqtt linked Presence sensor) and switch it OFF
after a fixed period of time.
I thought to realize that through 2 separate Items, like so:
Switch OfficeDirk_Light_Central "Suspension" <suspension> (OfficeDirk_Lights) ["Switch","Light"]
{channel="knx:device:_:__L:BDL1"}
Switch OfficeDirk_Light_CentralAuto "Suspension Auto" <suspension> (OfficeDirk_Lights) ["Switch","Light"]
{channel="knx:device:_:__L:BDL1", expire="15s,command=OFF"}
However, that doesn’t work as desired. The first OfficeDirk_Light_Central *Item*
also triggers the expire timer. I suspect that’s because the acknowledgment Group Address 1/2/111 changes the state of the second OfficeDirk_Light_CentralAuto *Item*
and hence starts the expire timer on that Item.
Any hint for a working setup, where the same thing can be manually switched through one item, while at the same time be motion-switched on and than timer-switched out?
