Hello
I have a onewire-system installed with several temperature and switch sensors. The temp-sensonrs work fine but the DS2401, which I put behind reed contacts to get the status of our windows either if they are open or not, I can not access. How can i get the status of each DS2401? I tried the examples like
Contact OneWireSensorA “Sensor A [%s]” {onewire=“deviceId=12.4AEC29CDBAAB;propertyName=sensed.A;invert;refreshinterval=15”}
I have the same setup (DS2401 for reed contacts and DS18B20 for temperature), but reading both kinds of sensors the same way was not practical. Measuring the temperature for 16 sensors takes >10 seconds, whereas reed contacts should report their state much faster. So I bought a dedicated 1-wire controller where I use one bus for (slow) temperature measurement (every 10min) and one for fast reed contacts (every 10sec).
The temperature sensors are properly read by openhab, but I didn’t manage to read the reed contact state properly.
My approach: a script that runs as a daemon on my raspberry pi and checks the owfs uncached state every 10 seconds. It also caches the state, and if one of the contacts is added to or removed from the 1-wire bus, it uses curl to update corresponding switch items via the openhab REST API. If someone is interested, I could post the script here…
This script runs as a daemon on my Raspberry Pi. The mapping from 1-wire IDs to openhab switch items is done in a 1-wire alias file.
#!/bin/bash
OPENHAB_SERVER=http://openhab:8080/rest/items
OPENHAB_LOGIN=user:password
ONE_WIRE_ALIAS=/mnt/openhab/1wire.alias
# get all available 1wire ibuttons from alias file
# a line from that files looks like that: 01.055773160000=01_wohnzimmer
ALL_IBUTTONS=$(grep 01_ $ONE_WIRE_ALIAS | sed 's/01.\+=01_\(.\+\)/\1/g' | sort)
#echo "all ibuttons: $ALL_IBUTTONS"
# store state to check which ibuttons changed
STATE=""
# unfortunately, there are many false alarms where individual contacts are reported open although they are not.
# so we only report open contacts if they are reported twice in a row
STATE2=""
# loop to check for presence
FIRSTRUN=1
while true
do
# check whether openhab server is running, otherwise don't do anything
SINGLE_STATE=$(curl -u $OPENHAB_LOGIN -s $OPENHAB_SERVER/Reed_wohnzimmer/state)
if [ ! "$SINGLE_STATE" == "" ]
# if state is uninitialized, clear cache and set all values again!
if [ "$SINGLE_STATE" == "Uninitialized" ]
STATE=""
STATE2=""
fi
# get all current reed contacts from uncached folder
REED=$(owdir /uncached | grep 01_ | sed 's/\/uncached\/01_//g' | sort)
# echo "all reeds: $REED"
# check state changes
if [ ! "$STATE" == "$REED" ] || [ ! "$STATE2" == "REED" ]
# iterate over all ibuttons and send updates
for button in $ALL_IBUTTONS
do
# echo "checking: $button..."
# the first run should always set the state
if [ $FIRSTRUN == 1 ]
# also set STATE to REED, which will be stored as STATE2, otherwise next iteration closed closed reeds again
STATE=$REED
# initialize CLOSED state
if [[ $REED =~ $button ]]
# echo "$button initialized to CLOSED"
curl -u $OPENHAB_LOGIN --header "Content-Type: text/plain" --request PUT --data "CLOSED" $OPENHAB_SERVER/Reed_$button/state
# initialize OPEN state
elif [[ ! $REED =~ $button ]]
# echo "$button initialized to OPEN"
curl -u $OPENHAB_LOGIN --header "Content-Type: text/plain" --request PUT --data "OPEN" $OPENHAB_SERVER/Reed_$button/state
fi
else
# if button is in reed but not in the last two states, it re-appeared
if [[ $REED =~ $button ]] && [[ ! $STATE =~ $button ]] && [[ ! $STATE2 =~ $button ]]
# echo "$button changed to CLOSED"
# if botton is not in reed but in the second last states, it disappeared
elif [[ ! $REED =~ $button ]] && [[ ! $STATE =~ $button ]] && [[ $STATE2 =~ $button ]]
# echo "$button changed to OPEN"
fi
fi
done
# unset variable because first run is over
FIRSTRUN=0
# save as new state
STATE2=$STATE
STATE=$REED
fi # state changed
fi #openhab is running
sleep 10 # run this loop every 10 seconds
done
