Hi all,
I cannot find it in the list. What’s wrong? Please advice!
Thanks in advance,
Pirx
BTW: Include Legacy 1.x … is of course enabled …
Hi all,
Thanks in advance,
Pirx
Can you see any 1.x bindings in Add-ons or only 2.x?
Have you choosed Simple at initial Setup?
I can see them all. No, I haven’t chosen minimal at initial Setup!
Just had a chat with a friend with a OH2.2 installation. He can’t see the OneWire GPIO as well. Hence it is not an isolated issue.
Wow! Sounds good
How to load the OneWireGPIO binding V2.3 separately ?
BTW: what’s behind the “GPIO Binding”? I can see it in may OH 2.2 as well. When I click on the name “Error: 404” appears !?
Both problems sound like you have a basic problem with your overall openHAB setup.
Thanks, but you gave me a wrong link. This link is correct
https://openhab.ci.cloudbees.com/job/openHAB2-Bundles/lastStableBuild/org.openhab.binding$org.openhab.binding.onewiregpio/
To the second point: no, I don’t think so. There is simply no content behind … https://docs.openhab.org/addons/bindings/gpio/readme.html
Pirx
Upps, s**t happens …
Maybe you are on a buggy version, it works fine with the latest snapshot.
Have fun.
I installed OneWire GPIO binding V2.3 manually and now it works !
We can close this thread.
Many thanks for support!
@Pirx could You please share items and sitemap? I’m struggling with DS18B20 sensors, and I can’t get them to work. I’m just starting with openHAB and raspberry, so probably I messed something up
Z góry wielkie dzięki
Sure Misiu, but I‘m just at the airport and will return tomorrow afternoon. Hence allow a delay of 20 hours to respond to your request I will help you then!
In the meantime … : are you able to read the OneWire device on OS level with ‚cat‘ ?
@Pirx yes, I am able to list devices inside /sys/bus/w1/devices. I’ve follower steps here, basically I’ve added:
dtoverlay=w1-gpio,gpiopin=4
to config.txt
when I ls
in that dir I get:
28-0316b15eb8ff 28-0316b18032ff w1_bus_master1
@Misiu, now I’m back home and can help you.
Lets go step by step:
1. when you execute the following command on the shell, do you get an response similar to this one (I assume the link is correct!?)
cat /sys/bus/w1/devices/w1_bus_master1/28-0316b15eb8ff/w1_slave
3e 01 ff ff 7f ff ff ff b3 : crc=b3 YES
3e 01 ff ff 7f ff ff ff b3 t=19875
btw “t=19875” eqauls to temperature of 19.875 °C
2. Now, you should check weather the Binding is installed and active. Open the karaf console and do the following… Tell me the output
openhab> bundle:list | grep OneWireGPIO
235 │ Active │ 80 │ 2.3.0.201801282104 │ OneWireGPIO Binding
Is the answer similar?
3. If everything is OK so far you can edit /etc/openhab2/things/yourfilename.things and add the following line
onewiregpio:sensor:myroomsensor "Temp. My Room" [gpio_bus_file="/sys/bus/w1/devices/w1_bus_master1/28-0316b15eb8ff/w1_slave",refresh_time=30]
For steps 3 and 4 it’s recommanded to have a karaf console opened in another shell window and constantly observe the log (command log:tail) . When you save the things and the items file you can see weather any errors or warnings appear caused by wrong entries you did !
4. Add now an Item in the /etc/openhab2/items/yourfilename.items
Number Temp_MyRoom "Temp. My Room [%.1f °C]" <temperature> { channel="onewiregpio:sensor:myroomsensor:temperature" }
5. wait 30 seconds and execute in the karaf console the following
openhab> items list | grep Temp_MyRoom
Temp_MyRoom (Type=NumberItem, State=19.875, Label=Temp. My Room, Category=temperature)
If it works, you are ready to create a visualisation with Sitemap or HAPpanel or whatever you are using.
The second sensor can be added in the similar way.
Pozdrowienia!
Pirx
@Pirx thank You for Your time.
I found the cause of my problem.
I’ve followed steps from here: https://github.com/openhab/openhab2-addons/tree/master/addons/binding/org.openhab.binding.onewiregpio
in things configuration there is this entry:
Thing onewiregpio:sensor:livingRoom “Living room” [gpio_bus_file="/sys/bus/w1/devices/28-0000061b587b/w1_slave",refresh_time=30]
but in items file there is this entry:
Number LivingRoomTemperature “Temperature: [%.2f °C]” { channel=“onewiregpio:sensor:livingroom:temperature” }
so when I replaced capital R with lower r everything started working
aaah. very good. You’ve found it.
Take care Misiu!
Pirx
