i get this exception every 10 seconds. Any clue where to search or what could be the problem? The binding is working though (Switch on/off the receiver etc)
I’m running the latest snapshot of OH2 on rpi2 and Onkyo Binding 2.0.0.SNAPSHOT which is in offline-distribution.
2016-11-09 10:49:39.550 [ERROR] [b.binding.onkyo.internal.eiscp.Eiscp] - Event listener invoking error
java.lang.NumberFormatException: For input string: "N/"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)[:1.8.0_111]
at java.lang.Integer.parseInt(Integer.java:580)[:1.8.0_111]
at org.openhab.binding.onkyo.handler.OnkyoHandler.statusUpdateReceived(OnkyoHandler.java:314)[199:org.openhab.binding.onkyo:2.0.0.201611072258]
at org.openhab.binding.onkyo.internal.eiscp.Eiscp.waitStateMessages(Eiscp.java:459)[199:org.openhab.binding.onkyo:2.0.0.201611072258]
at org.openhab.binding.onkyo.internal.eiscp.Eiscp.access$1(Eiscp.java:338)[199:org.openhab.binding.onkyo:2.0.0.201611072258]
at org.openhab.binding.onkyo.internal.eiscp.Eiscp$DataListener.run(Eiscp.java:494)[199:org.openhab.binding.onkyo:2.0.0.201611072258]
I’ve got a TX-NR609 which isn’t supported, and I’m using the 2.0.0.b4 binding. I don’t have the option to select zone (even though I’m pretty sure the amp has a zone 2).
What happens if you disable the zone channel in PaperUI -> Configuration -> Things and clicking on the Onkyo Binding
