I tried the following configuration:
ITEMS
String onkyoNETList “List [%s]” (Onkyo1) {onkyo=“*:onkyo1:#NLS”}
String onkyoNETList0 “1 [%s]” (Onkyo1)
String onkyoNETList1 “2 [%s]” (Onkyo1)
String onkyoNETList2 “3 [%s]” (Onkyo1)
String onkyoNETList3 “4 [%s]” (Onkyo1)
String onkyoNETList4 “5 [%s]” (Onkyo1)
String onkyoNETList5 “6 [%s]” (Onkyo1)
String onkyoNETList6 “7 [%s]” (Onkyo1)
String onkyoNETList7 “8 [%s]” (Onkyo1)
String onkyoNETList8 “9 [%s]” (Onkyo1)
String onkyoNETList9 “10 [%s]” (Onkyo1)
SITEMAP
Frame label="Navigation" {
Switch item=onkyoNETReturn
Switch item=onkyoNETUp
Switch item=onkyoNETDown
Selection item=onkyoNETService mappings=[0="Media Server (DLNA)", 1=Favorite, 2=vTuner, 3=SIRIUS, 6="Last.fm", 14="TuneIn Radio"]
Selection item=onkyoNETSelectList mappings=[0="1", 1="2", 2="3", 3="4", 4="5", 5="6", 6="7", 7="8", 8="9", 9="10"]
Frame label="List" {
Text item=onkyoNETList0
Text item=onkyoNETList1
Text item=onkyoNETList2
Text item=onkyoNETList3
Text item=onkyoNETList4
Text item=onkyoNETList5
Text item=onkyoNETList6
Text item=onkyoNETList7
Text item=onkyoNETList8
Text item=onkyoNETList9
RULES
import org.openhab.core.library.types.*
import org.openhab.core.library.items.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import java.util.concurrent.locks.ReentrantLock
import java.util.List
import java.util.ArrayList
var ReentrantLock onkyoLock = new java.util.concurrent.locks.ReentrantLock()
val List onkyoList = newArrayList (
onkyoNETList0,
onkyoNETList1,
onkyoNETList2,
onkyoNETList3,
onkyoNETList4,
onkyoNETList5,
onkyoNETList6,
onkyoNETList7,
onkyoNETList8,
onkyoNETList9
val String onkyoIndex = “0123456789”
- This rule processes Onkyo list updates and stores each one to a separate string element.
rule “Update List Item”
Item onkyoNETList changed
onkyoLock.lock()
try {
logDebug(“onkyo.rules”, onkyoNETList.state.toString())
var String state = onkyoNETList.state.toString()
var i = 0
while(i < 10) {
if(state.charAt(1) == onkyoIndex.charAt(i)){
postUpdate(onkyoList.get(i), state.substring(3))
i = i + 1
} finally{
onkyoLock.unlock()
However, I found from the log that the receiver is sending the status update events too fast for openhab to process. I would see log lines from the binding about processing each status update line, and lines from the rule about processing each update, but they were not in sync. Usually the rule would end up being called 10 times with the value of the last update. Sometimes some intermediate values would be processed. Here is some of the relevant output:
LOGFILE
xml.transform.stream.StreamSource@18d2b4a’
01:34:44.994 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU1-Recent Launches’ to data type class org.openhab.core.library.items.NumberItem
01:34:44.998 [DEBUG] [.b.onkyo.internal.OnkyoBinding:334 ] - Received status update ‘NLSU2-My Added Stations’ from device 192.168.100.65
01:34:45.000 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU2-My Added Stations’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.002 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU2-My Added Stations’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.004 [DEBUG] [.b.onkyo.internal.OnkyoBinding:334 ] - Received status update ‘NLSU3-Local Stations’ from device 192.168.100.65
01:34:45.006 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU3-Local Stations’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.018 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU3-Local Stations’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.019 [DEBUG] [.b.onkyo.internal.OnkyoBinding:334 ] - Received status update ‘NLSU4-Stations By Genre’ from device 192.168.100.65
01:34:45.022 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU4-Stations By Genre’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.023 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU4-Stations By Genre’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.025 [DEBUG] [.b.onkyo.internal.OnkyoBinding:334 ] - Received status update ‘NLSU5-Stations By Location’ from device 192.168.100.65
01:34:45.028 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU5-Stations By Location’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.030 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU5-Stations By Location’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.032 [DEBUG] [.b.onkyo.internal.OnkyoBinding:334 ] - Received status update ‘NLSU6-New Stations’ from device 192.168.100.65
01:34:45.036 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU6-New Stations’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.038 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU6-New Stations’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.040 [DEBUG] [.b.onkyo.internal.OnkyoBinding:334 ] - Received status update ‘NLSU7-Most Popular Stations’ from device 192.168.100.65
01:34:45.042 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU7-Most Popular Stations’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.044 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU7-Most Popular Stations’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.046 [DEBUG] [.b.onkyo.internal.OnkyoBinding:334 ] - Received status update ‘NLSU8-Search Stations’ from device 192.168.100.65
01:34:45.049 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU8-Search Stations’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.053 [DEBUG] [.b.onkyo.internal.OnkyoBinding:334 ] - Received status update ‘NLSU9-Buzz’ from device 192.168.100.65
01:34:45.054 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule ‘Update List Item’
01:34:45.055 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU9-Buzz’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.059 [DEBUG] [.b.onkyo.internal.OnkyoBinding:413 ] - Cannot convert value ‘NLSU9-Buzz’ to data type class org.openhab.core.library.items.NumberItem
01:34:45.095 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule ‘Update List Item’
01:34:45.112 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule ‘Update List Item’
01:34:45.128 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule ‘Update List Item’
01:34:45.144 [DEBUG] [enhab.model.script.onkyo.rules:38 ] - U4-Stations By Genre
01:34:45.147 [DEBUG] [.i.s.XsltTransformationService:89 ] - transformation resulted in ’
01:34:45.148 [DEBUG] [.o.b.http.internal.HttpBinding:197 ] - transformed response is ’
01:34:45.149 [DEBUG] [.o.b.http.internal.HttpBinding:262 ] - Couldn’t create state of type ‘class org.openhab.core.library.items.NumberItem’ for value ’
01:34:45.149 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule ‘Update List Item’
01:34:45.167 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule ‘Update List Item’
01:34:45.184 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule ‘Update List Item’
01:34:45.200 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule ‘Update List Item’
01:34:45.217 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule ‘Update List Item’
01:34:45.232 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule ‘Update List Item’
01:34:45.244 [DEBUG] [ore.internal.items.ItemUpdater:73 ] - Received update of a not accepted type (StringType) for item Weather_Temperature
01:34:45.369 [DEBUG] [enhab.model.script.onkyo.rules:38 ] - U9-Buzz
01:34:45.582 [DEBUG] [enhab.model.script.onkyo.rules:38 ] - U9-Buzz
01:34:45.805 [DEBUG] [enhab.model.script.onkyo.rules:38 ] - U9-Buzz
01:34:46.002 [DEBUG] [enhab.model.script.onkyo.rules:38 ] - U9-Buzz
Next I tried the following with no rule:
ITEMS
String onkyoNETList0 “1 [%s]” (Onkyo1) {onkyo=“:onkyo1:#NLSU0"}
String onkyoNETList1 “2 [%s]” (Onkyo1) {onkyo=":onkyo1:#NLSU1”}
String onkyoNETList2 “3 [%s]” (Onkyo1) {onkyo=“:onkyo1:#NLSU2"}
String onkyoNETList3 “4 [%s]” (Onkyo1) {onkyo=":onkyo1:#NLSU3”}
String onkyoNETList4 “5 [%s]” (Onkyo1) {onkyo=“:onkyo1:#NLSU4"}
String onkyoNETList5 “6 [%s]” (Onkyo1) {onkyo=":onkyo1:#NLSU5”}
String onkyoNETList6 “7 [%s]” (Onkyo1) {onkyo=“:onkyo1:#NLSU6"}
String onkyoNETList7 “8 [%s]” (Onkyo1) {onkyo=":onkyo1:#NLSU7”}
String onkyoNETList8 “9 [%s]” (Onkyo1) {onkyo=“:onkyo1:#NLSU8"}
String onkyoNETList9 “10 [%s]” (Onkyo1) {onkyo=":onkyo1:#NLSU9”}
However, I found that the binding must only be looking at the first three characters of the command “NLS” as the items were updated with every line sent, not just the line intended for them. Is there any way the binding could be modified to match the whole command instead of just a portion of it? Note that the command is never sent by openhab, the receiver sends the status update events automatically. So maybe the binding needs some type of indication that it is an input and some processing expression like the HTTP binding has.
~petev
