I am currently testing Onkyo Binding to run my Integra DRX7(comes out of the same factory as Onkyo.
The binding works fine. The only issue I have is that by default the DRX7 volume gets changed up and down by 0.5dB. So any adjusts I make via sitemap only sets the volume halfway. So 100=50 etc.
Any ideas to what I could change make the volume change double?
It sounds that you have enabled Onkyo binding volume limit functionality from the binding configuration? See more details from http://docs.openhab.org/addons/bindings/onkyo/readme.html. If not, maybe Integra volume scale is different that is specified for Onkyo models. You could enable Onkyo binding debug logs (TRACE level give most information) to see more details.
Thanks for the reply. I added the onkyo binding through the Paper UI and not .bindings file.
In the paper ui when i go to configure the onkyo binding i see there is a volumelimit set to 100. But also when I edit the thing for the the drx7 that i added there is a volumelimit to 100 as well. How do i remote these values?
in my item file i have the following dimmer set up for volume
// Volume
Dimmer onkyoVolume “Volume [%d]” {onkyo=“INIT:onkyoAVR:VOLUME_QUERY, INCREASE:onkyoAVR:VOLUME_UP, DECREASE:onkyoAVR:VOLUME_DOWN, *:onkyoAVR:VOLUME_SET”}
on the link above it mentions advanced commands
Advanced commands
If you want to use commands that are not predefined by the binding you can use them with a shape # as a prefix.
example 1: Dimmer volume { onkyo=“INCREASE:hometheater:VOLUME_UP, DECREASE:hometheater:VOLUME_DOWN, *:hometheater:#MVL%02X” }
Installed the Onkyo 2.1.0 binding from Paper UI.
Then create a .thing file with onkyo:onkyoAVR:myOnkyo [ipAddress=“192.168.2.167”, port=60128]
Then create a .items file from link above
Then create a .sitemap file from link above
Again everything works fine. Except the volume steps on sitemap are +1 but on amp its 0.5.
Is there a way for me to access and change the binding settings for the volume stepping and or the volume limit?
I am think that it either the limit can be set to 200 or the stepping at x 2 it might work?
Currently, binding supports correctly only receivers which volume level is between 0-100. Limit functionality does not amplify the value, it’s only purpose is to limit volume level, so that user cannot accidentally put the volume to full.
Unfortunately not, volume channel is a dimmer channel which doesn’t accept bigger values than 100. I think that only way to do at moment is to use older OH1 binding.
