Hello!
I’ve been trying to write a rule that essentially debounces a contact. I want to receive an email if and only if the state of said contact was changed and has remained changed for a given time. This is what I have tried so far:
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.joda.time.*
var Timer timerNeato
var OpenClosed stateNeato
rule "Neato Basisstation"
Item hmK1State changed from OPEN to CLOSED or
Item hmK1State changed from CLOSED to OPEN
if(timerNeato==null || stateNeato==null)
stateNeato = (hmK1State.state as OpenClosedType)
if(timerNeato!=null)
timerNeato.cancel
timerNeato=null
timerNeato = createTimer(now.plusSeconds(30)) [|
if (hmK1State.state==stateNeato)
var String Titel = "Neato "
var String Meldung = "Neato is "
if (hmK1State.state == OPEN)
Titel = Titel + "started"
Meldung = Meldung + "started"
else
Titel = Titel + "back home"
Meldung = Meldung + "back home" }
sendMail("myemail", Titel, Meldung)
timerNeato=null
My idea was that if no timer is running, I save the current state to a variable. If the timer is running, I will restart it, but preserve the original value.
If the timer runs out and the current state of the contact is identical from the state when the first change was detected, the contact has remained changed and I will send an e-mail.
My problem is that the comparison in the timer (if(hmK1State.state==stateNeato)) gives me an awful exception.
==> openhab.log <==
2016-06-17 17:47:38.216 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2016-06-17T17:47:37.492+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@1fc2dc3 (explicitSyntax: true) threw an unhandled Exception:
java.lang.IllegalStateException: Could not invoke method: org.openhab.model.script.lib.NumberExtensions.operator_equals(org.openhab.core.types.Type,java.lang.Number) on instance: null
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:738) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) ~[na:na]
at sun.reflect.GeneratedMethodAccessor80.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_65]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na]
at sun.reflect.GeneratedMethodAccessor77.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(XbaseInterpreter.java:327) ~[na:na]
at sun.reflect.GeneratedMethodAccessor89.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at sun.reflect.GeneratedMethodAccessor85.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:28) ~[na:na]
at com.sun.proxy.$Proxy81.apply(Unknown Source) ~[na:na]
at org.openhab.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:44) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) ~[quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
Caused by: java.lang.IllegalArgumentException: argument type mismatch
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_65]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) ~[na:na]
... 31 common frames omitted
2016-06-17 17:47:38.456 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2016-06-17T17:47:37.492+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@1fc2dc3 (explicitSyntax: true) threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:224) ~[quartz-all-2.1.7.jar:na]
Caused by: java.lang.IllegalStateException: Could not invoke method: org.openhab.model.script.lib.NumberExtensions.operator_equals(org.openhab.core.types.Type,java.lang.Number) on instance: null
... 1 common frames omitted
I am at a loss at what’s going on here. Any idea what is happening there?
