Apologies for bumping my own thread, but this is driving me crazy. It must be something simple. I have reinstalled to last nights build (not because of this issue) but still not working.
OH2 has an auto generated sitemap at “/rest/sitemaps/_default” whose label is “Home” , so you are seeing yours as well as the system one. If you select the other “Home” sitemap, do you not see your version? I have the same setup and can switch between the two even though they have the same label “Home”
If I select “My Home” I get a 500 Error. When I select “Home” I get just Things. And based on your response I now understand that to be the default and not actually my custom sitemap.
If you are getting a 500 error, my guess is that something is wrong with your sitemap and the server cannot parse it. What happens when you hit the /rest/sitemaps/home in a browser ?
