Hi folks,
maybe someone here is using opendaikin and can help me with this log:
2019-05-04 13:22:48.153 [WARN ] [rnal.handler.OpenDaikinAcUnitHandler] - Received command of wrong type for thing 'opendaikin:ac_unit:attic_ac' on channel humidity
2019-05-04 13:22:48.163 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: org.eclipse.smarthome.core.types.RefreshType cannot be cast to org.eclipse.smarthome.core.library.types.StringType
java.lang.ClassCastException: org.eclipse.smarthome.core.types.RefreshType cannot be cast to org.eclipse.smarthome.core.library.types.StringType
at org.openhab.binding.opendaikin.internal.handler.OpenDaikinAcUnitHandler.handleCommandInternal(OpenDaikinAcUnitHandler.java:87) ~[?:?]
at org.openhab.binding.opendaikin.internal.handler.OpenDaikinAcUnitHandler.handleCommand(OpenDaikinAcUnitHandler.java:69) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.channelLinked(BaseThingHandler.java:232) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:300) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2019-05-04 13:22:48.204 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: org.eclipse.smarthome.core.types.RefreshType cannot be cast to org.eclipse.smarthome.core.library.types.StringType
at org.openhab.binding.opendaikin.internal.handler.OpenDaikinAcUnitHandler.handleCommandInternal(OpenDaikinAcUnitHandler.java:93) ~[?:?]
2019-05-04 13:22:48.228 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: org.eclipse.smarthome.core.types.RefreshType cannot be cast to org.eclipse.smarthome.core.library.types.StringType
2019-05-04 13:22:48.171 [WARN ] [rnal.handler.OpenDaikinAcUnitHandler] - Received command of wrong type for thing 'opendaikin:ac_unit:attic_ac' on channel outdoortemp
2019-05-04 13:22:48.170 [WARN ] [rnal.handler.OpenDaikinAcUnitHandler] - Received command of wrong type for thing 'opendaikin:ac_unit:attic_ac' on channel indoortemp
2019-05-04 13:22:48.167 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: org.eclipse.smarthome.core.types.RefreshType cannot be cast to org.eclipse.smarthome.core.library.types.OnOffType
java.lang.ClassCastException: org.eclipse.smarthome.core.types.RefreshType cannot be cast to org.eclipse.smarthome.core.library.types.OnOffType
at org.openhab.binding.opendaikin.internal.handler.OpenDaikinAcUnitHandler.handleCommandInternal(OpenDaikinAcUnitHandler.java:80) ~[?:?]
2019-05-04 13:22:48.234 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: org.eclipse.smarthome.core.types.RefreshType cannot be cast to org.eclipse.smarthome.core.library.types.StringType
at org.openhab.binding.opendaikin.internal.handler.OpenDaikinAcUnitHandler.handleCommandInternal(OpenDaikinAcUnitHandler.java:90) ~[?:?]
It seems the binding is working, but I would like to understand the log.
Thanks for your support
Kind Regards
Andrea
