After a brand new clean installing OH 1.7.1, my openhab.log file is full with the error below (there rate is about 50ms which is by the way simply killing my Raspsberry SD card )
2015-12-23 15:38:30.854 [ERROR] [.service.AbstractActiveService] - Error while executing background thread Souliss Refresh Service
Current solution is to remove the addons/org.openhab.binding.souliss-1.7.1.jar file.
Any idea when a fix will be ready for that issue
Robert
Could you try the current org.openhab.binding.soullis.1.8.0-SNAPSHOT.jar binding in the addons.zip here? (remove the current JAR and put the new JAR in your addons folder)
Do you have any more configuration or logs that might help diagnose the issue? Hopefully @fazioa or another contributor or maintainer can take a look.
Don’t know about the Souliss binding, but you could write the logs to a tmpfs instead. In addition a higher commit value (commit=300) in /etc/fstab is useful.
Have you tried using the addon-jar from the 1.8.0 SNAPSHOTS?
